Results 1 to 9 of 9
Thread: How do I remove this section of pipe?
    DIY Junior Member Chris Hunt's Avatar
    Jul 2011
    Michigan
    Default How do I remove this section of pipe?
    I have the nut removed, but it won't budge. What am I doing wrong? Thanks in advance!
    It's toast buddy.
    Just reef on that sucker. You might even have to take a flat blade to it and pry the mother out.
    When you replace the p-trap, get a new slip joint nut and washer to thread and seal to the galv nipple.
    You can even replace the nipple if you need to.
    You aren't doing anything "wrong". The inside of the pipe is rusted so the tubing is "trapped". You have to take a screwdriver or chisel and pry between the pipe and the tubing to "collapse" it. Then you can remove the tubing, but do not expect to have an easy time inserting a new piece, unless you ream the rust out of the pipe.
    Side note; Obama, hopefully, in a year or so you will have competition for that name and icon.
    Mar 2011
    Long Island, NY
    lol! NOW THAT IS FUNNY!
    Mar 2011
    Houston, TX
    Quote Originally Posted by BobL43 View Post
    I second that emotion...lol
    DonL
    Aug 2009
    South*East
    I think most of us would like to see that name removed from the Whitehouse. Then we may be able to get back on the right track.
    John
    Mar 2011
    Houston, TX
    Quote Originally Posted by johnjh2o1 View Post
    John
    I agree, Then he can become a Plumber, something that maybe he would be better at...
    Quote Originally Posted by Chris Hunt View Post
    Chris You are not holding your mouth just right. Putting a little CLR on it may help break it loose.
    DonL
    Aug 2009
    South*East
    I think that is a insult to the trade. Maybe he can become shovel ready. (sorry labors didn't mean that as a insult to you) I better get off this subject as my blood pressure is rising.
    John
    Mar 2011
    Houston, TX
    I am sorry John, Chris and the group. (And Terry)
    This should be on Ian's Corner. He must be rubbing off.
    If I was talking out my ass, I apologize to all. But you are correct John, Sorry for the insult.
    Have a Great Day all.
    DonL
  1. Need to remove section of air pipe (stuck), thoughts?
    By ratboyslim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2010, 05:42 PM
  2. repairing a section of cpcv pipe
    By huliman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2010, 06:11 AM
  3. Rejoin 1" in-slab radiant pipe after removing rusted section
    By mbaltay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2008, 02:09 PM
  4. Can I install toilet vent in vertical section of pipe below toilet?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2008, 10:36 AM
  5. Replacing section of sewer pipe
    By Lakee911 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2008, 11:46 AM
