Thread: pump won't prime
    DIY Junior Member no luck's Avatar
    Jul 2011
    maryland
    Default pump won't prime
    I have 20 year old shallow well used for irrigation with 1 Hp pump that came with the house. I replaced the pump abourt 4 years ago. has usuallly worked without any hitches. this year in the spring pump would prime but not hold it. I would have to reprime every morning. Now I can't get it to prime at all. system holds vacuum I can here it release when i break into system. I have tried flushing out the well with a hose down the well. no Joy. Is screen clogged? Do I need to sink a new well? Ideas please
    Mar 2011
    Houston, TX
    Welcome to Terry's Forums no luck,
    Having the Model number of your pump may help.
    When you put water in the well, does it take the water or just fill up the pipe ?
    What is the casing size of your well ?
    Have a good day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Jan 2008
    Virginia Beach, VA
    You have a leak in the suction line or possibly a bad check valve. Shallow driven wells in our area usually last 20 years give or take 10 years. I'd say the life of your wel is nearing it's end.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Nov 2010
    Maine
    Have you looked down the hole to see if theres any water there?
  1. Pump Won't Prime or hold prime
    By PAmom1991 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-31-2011, 07:09 AM
  2. Pump lost prime - won't prime (long post)
    By BWFRJR in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-30-2010, 06:37 PM
  3. Jet pump won't prime. Next?
    By mistermango in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-30-2009, 05:27 PM
  4. pump will not prime
    By oley in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2008, 11:05 AM
  5. Well pump wont prime
    By mifirecop in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-25-2007, 10:45 AM
