Results 1 to 4 of 4
Thread: trouble shooting low voltage control operates high volt can lights
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Default trouble shooting low voltage control operates high volt can lights
    Have not looked at this will be going there in 1 hour.
    Have 8 cans in a church 1 works the rest do not.
    Will update later.
    I have access to the cans above the sanctuary.
    Do not know where the control panel is yet.
    Get your minds rolling I may need your help!
    Obvious things are either a loose wire or SEVEN burned out bulbs.
    Aug 2007
    Cincinnati OH
    Two circuts 16 lights not working, by passed the low volt switches got to go to attic
    above sanctuary 60ft with no catwalk 140 plus degrees up there today.
    Will go in morning.I know pretty much where problem is but I have to go from one end to the other to get to first box. I have worked on this church many times and it is old with new I am working where old meets new.Not fun!
    Aug 2007
    Cincinnati OH
    Problem solved bad connection in first box how it lasted as long as it did I don`t know.
  1. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  2. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
  3. Trouble-shooting a WX 202?
    By gram in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-21-2008, 04:09 PM
  4. Water Heater Trouble Shooting
    By IaHawk in forum Plumbing Forum Discussion & Blog
    Last Post: 03-28-2008, 06:55 AM
  5. Electric Water Heater trouble shooting..???
    By Randyj in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2007, 09:14 PM
