Results 1 to 2 of 2
Thread: goulds pump
    DIY Junior Member marquezrf's Avatar
    Jul 2011
    Ca.
    Default goulds pump
    i have a goulds pump, c48a94a08, 3/4 hp, that i just recently repaired the plumbing on. the problem i have is that while i was priming everything was ok, now when plumbing is completed the pump is making a whizzing noise and when it reaches the optimal pressure it will stop for a second then click back on 2 times, the thing is it wont hold pressure. once it does this a few times the switch will stay connected and pump will turn off. therefore i have to turn breaker off so that the switch will not burn out. i am thinking maybe the propelles went bad.
    Moderator valveman's Avatar
    Mar 2006
    Sounds like you have a check valve between the pump/switch and pressure tank. You need a check or foot valve on the suction, but not before the pressure tank.
  1. Need Help Removing Impeller from Goulds JS+ pump
    By Pinckman in forum Irrigation / Sprinkler Forum
    Last Post: 02-06-2010, 02:19 PM
  2. Questions on Goulds 5GS pump
    By laffin_boy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-20-2009, 06:02 PM
  3. Goulds Jet Pump Switch Problem - Please Help!
    By rchaney99 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-12-2009, 06:38 PM
  4. Help removing goulds J5 pump impeller.
    By joe_farmer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-20-2009, 07:02 AM
  5. goulds jet pump hot to touch @55psi
    By ceramicbrad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2006, 11:39 AM
