Results 1 to 3 of 3
Thread: 3" Tub drain replacement
Hybrid View
    DIY Junior Member loop1's Avatar
    Jul 2011
    Frederick, MD
    Default 3" Tub drain replacement
    My bathtub's "drain spud" (the flanged outlet through which the water leaves the tub) is brass, ugly, and we must use a rubber stopper in it as any "mechanical stopper" is long gone from the overflow pipe. I figured I could just remove this "spud" and replace it with a chromed pop-up fitting, or if necessary replace the whole outlet/overflow assembly with a new one in chrome (to match the other chrome bath fittings). The diameter of the flanged part of the spud is THREE inches, and no pop up or complete assembly I can find anywhere has a flange as big as 3 inches. (Well, my local plumbing supplier found a Kohler chromed complete assembly, but I cannot pay the $300 price tag.) I must have one with a full 3 inch flange diameter because the porcelain under the flange is cracked or missing and a smaller flange will show these imperfections. I have spent hours on Google looking for a replacement in chrome with a 3 inch diameter flange, with no luck. Any help will be appreciated. Thanks
    DIY Junior Member afrancis's Avatar
    Nov 2011
    MD
    Default ANy luck?
    Hi Loop1
    Have you had any luck finding a 3" replacement flange? I would like to find 2 for my home as the smaller ones tend to have a space around their outter edge that holds water. My two tubs are from the late 40's and late 50's but need the 3" American Standard drain.
    Appreciate any clues to your success.
    In both cases, the 3" strainer will NOT be generic, so even if you find a new one, it would probably NOT have the proper thread, so you may have to buy the entire drain and replace everything.
  1. tub drain - trap replacement? <pic>
    By jeremytl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-27-2010, 05:20 AM
  2. Spartan no 363 drain replacement
    By firm in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2008, 10:32 AM
  3. Replacement Shower Drain
    By rdtompki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2006, 04:58 PM
  4. Tub Drain Stopper Replacement
    By Don Zorn in forum Shower & bathtub Forum & Blog
    Last Post: 01-23-2005, 05:01 PM
  5. Tub Drain Replacement
    By slippery_pete in forum Shower & bathtub Forum & Blog
    Last Post: 10-09-2004, 01:37 PM
