Originally Posted by
DarkNova
Yes, I have a pitless. I agree about doing it with 2" if I were to do it all over again, unfortunately that would be pretty difficult to do at this stage. And yes, the pipe immediately connected to the pump was also filled with iron. It is 1" PVC and the walls inside were coated so much that the actual space for water to travel was only about a pencil's width wide. Fortunately it was pretty easy for them to change that pipe as our well is only 41' deep so there was only like 33' of pipe leading down to the pump. For people with deep wells that would be much more of a hassle. When the pump was pulled up, it was also coated with orange iron build-up. They washed the pump and soaked it in iron-out overnight. Its an interesting theory about aeration causing iron to precipitate out, I'm just not sure how to test that and what I would do about it.
