Page 7 of 7 FirstFirst 1234567
Results 91 to 98 of 98
Thread: Bathtub installation -- order of installation (end pony wall, tub, heated floor)?
  1. #91
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Back from vacation; just returned a whole batch of stone tile that wasn't fit for sale; and back in action.
    I've coated the shower surround area with AquaDefence, but it's so dark (dark green) that I don't know what to use to mark my tiling guidelines. Black Sharpie is invisible on this stuff!
    What do you people use to mark lines on AquaDefence when you're tiling??
    - John
  2. #92
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by jch View Post
    Give it a scratch coat of thin-set first. This will make life easier for you. The dark colour is my only beef with the product.
    JW
    JW
    "When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
    Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
  3. #93
    Jan 2006
    Floor is now done and grouted.
    Stone backsplash wall is now done and grouted.
    Considering using the leftover stone (0.6 x 6" stone mosaic) as a baseboard strip (a 2" high strip around the edge of the room).
    Problem is that I've already mudded (with non-setting mud) the walls. I'm concerned that thinset will dissolve the mud and the tiles will fall off.
    What can I do to provide a solid base for this thin strip of tiles along the floor?
    - Prime the walls first?
    - Paint on a narrow band of AquaDefence?
    - Something else??
    Surely this is a common problem...
    - John
  4. #94
    Jul 2009
    North Vancouver, BC
    Hi John.
    Lets see some progress pictures!
    If you have drywall compound on the walls already you will not get any thin-set to bite to it.
    I have been experimenting with different primers and found a good one from Mapei called Prim-Grip. I would first give the drywall a primer coat with a latex or oil based dry wall primer (paint kind) - Zissner 123 or Zissner Cover Coat my favourites. For a baseboard detail you would most likely do alright with either one but if you want an even better bond pick up a gallon of the Prim-Grip.
    The Prim-Grip has sand or something in it so stir it very well. This leaves a rough texture on the wall that thinset bites to very well.
    JW
  5. #95
    Jan 2006
    I agree--Zinsser 1-2-3 is my favourite primer too. I only need about 4 square feet covered and Prim-Grip's smallest can is 1 gallon so I'm going to see whether the 1-2-3 will work instead.
    In terms of updates, here we go...
    Here's the finished floor:
    Here's the finished stone backsplash wall:
    Here's the opening for the toilet flange -- a tricky cut on the saw. Even though I knew the floor would end up thick, it was shocking to actually see how thick it was in person: 3/4" T&G exterior grade plywood + 1/2" SLC (encapsulating heating wire and plastic lath) + Ditra + 3/8" Porcelain tile:
    I used a laser to keep things straight and square. The LASH clips were fine when working off a wet edge, but horrible when trying to continue the next day (I did all the field tiles first, just in case it got misaligned a bit. After 2 days, I went back and did all the edge piece cuts.) With practice, lippage became a non-issue.
    - John
  6. #96
    Jan 2006
    Smile
    Getting closer.... Shower glass is in.
    Still to do:
    - final plumbing hookup
    - stone baseboard
    - mirror
    - frosted glass bypass doors (and shelves) in closet
    - seal grout on floor and walls (any recommendations??)
    - John
  7. #97
    Jul 2009
    North Vancouver, BC
    Looks like a gem John. Love the vanity
  8. #98
    Jan 2006
    Quote Originally Posted by johnfrwhipple View Post
    Magick Woods Sonata, from Home Cheapo. Despite that, I like it too
    - John
  1. Replies: 6
    Last Post: 05-06-2010, 03:21 PM
  2. pony wall for custom shower??help
    By tameria11 in forum Shower & bathtub Forum & Blog
    Last Post: 03-07-2008, 01:36 AM
  3. Installation order question
    By HoneyBunny in forum Toilet Forum discussions
    Last Post: 01-21-2008, 09:20 AM
  4. Tile bathroom floor before or after bathtub installation?
    By jch in forum Remodel Forum & Blog
    Last Post: 03-05-2007, 01:07 PM
  5. Order of installation for new floor?
    By skiemfast in forum Remodel Forum & Blog
    Last Post: 08-24-2006, 02:05 PM
