Back from vacation; just returned a whole batch of stone tile that wasn't fit for sale; and back in action.
I've coated the shower surround area with AquaDefence, but it's so dark (dark green) that I don't know what to use to mark my tiling guidelines. Black Sharpie is invisible on this stuff!
What do you people use to mark lines on AquaDefence when you're tiling??
- John
Floor is now done and grouted.
Stone backsplash wall is now done and grouted.
Considering using the leftover stone (0.6 x 6" stone mosaic) as a baseboard strip (a 2" high strip around the edge of the room).
Problem is that I've already mudded (with non-setting mud) the walls. I'm concerned that thinset will dissolve the mud and the tiles will fall off.
What can I do to provide a solid base for this thin strip of tiles along the floor?
- Prime the walls first?
- Paint on a narrow band of AquaDefence?
- Something else??
Surely this is a common problem...![]()
- John
Hi John.
Lets see some progress pictures!
If you have drywall compound on the walls already you will not get any thin-set to bite to it.
I have been experimenting with different primers and found a good one from Mapei called Prim-Grip. I would first give the drywall a primer coat with a latex or oil based dry wall primer (paint kind) - Zissner 123 or Zissner Cover Coat my favourites. For a baseboard detail you would most likely do alright with either one but if you want an even better bond pick up a gallon of the Prim-Grip.
The Prim-Grip has sand or something in it so stir it very well. This leaves a rough texture on the wall that thinset bites to very well.
JW
I agree--Zinsser 1-2-3 is my favourite primer too. I only need about 4 square feet covered and Prim-Grip's smallest can is 1 gallon so I'm going to see whether the 1-2-3 will work instead.
In terms of updates, here we go...
Here's the finished floor:
Here's the finished stone backsplash wall:
Here's the opening for the toilet flange -- a tricky cut on the saw. Even though I knew the floor would end up thick, it was shocking to actually see how thick it was in person: 3/4" T&G exterior grade plywood + 1/2" SLC (encapsulating heating wire and plastic lath) + Ditra + 3/8" Porcelain tile:
I used a laser to keep things straight and square. The LASH clips were fine when working off a wet edge, but horrible when trying to continue the next day (I did all the field tiles first, just in case it got misaligned a bit. After 2 days, I went back and did all the edge piece cuts.) With practice, lippage became a non-issue.
- John
Getting closer.... Shower glass is in.
Still to do:
- final plumbing hookup
- stone baseboard
- mirror
- frosted glass bypass doors (and shelves) in closet
- seal grout on floor and walls (any recommendations??)
- John
Looks like a gem John. Love the vanity
