Results 1 to 8 of 8
Thread: 4" shower drain
    DIY Member shag_fu's Avatar
    Feb 2008
    Illinois
    Default 4" shower drain
    Trying to find a 4" shower drain(pipe dia. Not strainer size) for a small pond. I may be referring to it wrong which would mess up my google search. Any help would be appreciated.
    Josh
    Nov 2010
    Maine
    No such thing but you could probably use a floor drain instead.
    Feb 2008
    Illinois
    There's an old one I'm trying to replace so yes there is such a thing. Like I said at that size it may be reffered to as something else. I'm on a phone but I'll try to post a pic of what I'm trying to replace.
    Nov 2010
    Maine
    Nobody makes a "shower drain" that will take 4" pipe. I'm sure you have a 4" drain but I'd bet that it's a floor or roof drain that has been adapted.
    "Floor drains" ARE shower drains, but your application would determine whether that is the best item for you usage.
    Feb 2008
    Illinois
    Ok so Ive done some more searching. Im looking for a 4" adjustable floor drain with membrane, the other way it may be listed is as an 8" shower grid. A 6" grid will go to a 3" drain which is probably good enough for my application. Now if only they would make em cheaper than $200 for a hunk of plastic...
    Nov 2010
    Maine
    If your gonna play you gotta pay
    quote; Now if only they would make em cheaper than $200 for a hunk of plastic...
    1. Who charges $200.00 for a "hunk of plastic"
    2. A cast iron one with a brass strainer would only cost a bit more than half that.
  1. Which cities in Canada have the "No Plastic" shower drain codes?
    By johnfrwhipple in forum Canadian Plumbing Code Questions
    Last Post: 01-07-2011, 11:02 PM
  2. shower drain forSterling 48" shower surround
    By timwise999 in forum Shower & bathtub Forum & Blog
    Last Post: 01-06-2011, 09:10 PM
  3. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
  4. shower base with 1 1/2" drain or 2"?
    By Carpenter in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2005, 12:08 PM
  5. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
    By paule123 in forum Shower & bathtub Forum & Blog
    Last Post: 06-12-2005, 10:15 AM
