Thread: Are there Eschucheons for cleanouts?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default Are there Eschucheons for cleanouts?
    For 2" abs cleanout, is there any sort of Eschucheons that will fit over? How do you pros keep the exposed cleanout looking decent in the wall, particularly if the drywall is not cut so tightly/neatly?
    Note that this is not 2" abs pipe, but is the larger diameter of the cleanout / hub.
    Nov 2010
    Maine
    google it, there are several companies that make round chrome clean out access covers.
    You either use a flat cleanout cover, or a "bell" shaped one if it projects from the wall. A countersunk plug rather than a square head one also helps many times.
  1. Where are cleanouts necessary?
    By GoDillos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-24-2009, 09:21 PM
  2. Cleanouts Questions
    By abrahuang in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-07-2007, 10:20 AM
  3. Is it necessary to add cleanouts? Also whether to tie in A/C condenser?
    By espeedy123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2007, 06:02 AM
  4. Cleanouts
    By Hazel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-04-2006, 07:04 AM
  5. Cleanouts?
    By Idaho Cabin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2005, 03:48 PM
