Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Grounding Bus Questions
  1. #16
    DIY Junior Member eric3872's Avatar
    May 2011
    new york
    Not everyone can see your pictures.
    If you have a older box then you may not have a separate ground bus.
    What ever bus that your box Ground rod is connected to is where the bare ground wire should be connected.
    DonL
    There does not appear to be a separate ground connection to either bus.
  2. #17
    May 2011
    new york
    If I am interpretting your photos correctly, it appears you have a pair of #10, or so, wires feeding the panel, and if so, that panel is much too "busy" for that feed. It appears that it would be stretching it even if they are #8s, and I really doubt that they are #6s.
    The main feed wires are definitely larger than #10. They are not labeled, so I can't tell what gauge, but they are at least twice the thickness of everything else in the panel.
  3. #18
    Are you COMPLETELY removing the tandem breakers AND the wiring to them? If so, and it was because they were not being used then they were not a factor in the original panel's load, and you are adding 25-30 amps to the panel.
  4. #19
    May 2011
    new york
    They are being completely removed. They feed outlets that are not being used. There are at least 4 dedicated circuits on this panel that feed outlets for window air conditioners. The previous owner must have had air conditioners in every window. I am removing two of these dedicated circuits to make room and have no intention of ever using the others. I was planning on removing the wires from the panel and capping/disconnecting at both ends (panel and outlet), otherwise I'd have to rip open walls all over the apartment to completely remove the wires. That being said, I would still like to test the panel to see how many amps it is drawing before I go ahead with this. What is the best way to test it?
  5. #20
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    You need an AMP meter.
  6. #21
    Mar 2011
    Houston, TX
    Turn everything on that you can, then use a clamp on meter at the input of the wires to the box. That will tell your total load.
    Be careful playing with electricity.
    DonL
  7. #22
    Dec 2009
    northfork, california
    The new subs [as in submarine] dont have true periscopes anymore. just a video screen feed
  1. Grounding questions
    By t20sl in forum Electrical Forum discussion & Blog
    Last Post: 10-06-2010, 03:22 PM
  2. grounding ?
    By web_surfer in forum Electrical Forum discussion & Blog
    Last Post: 11-27-2009, 11:38 AM
  3. Grounding questions: Gas, plumbing, appliances
    By lottia in forum Electrical Forum discussion & Blog
    Last Post: 08-14-2009, 11:41 AM
  4. some grounding questions
    By solutions in forum Electrical Forum discussion & Blog
    Last Post: 03-31-2008, 09:51 AM
  5. Q about grounding
    By alleycat in forum Electrical Forum discussion & Blog
    Last Post: 08-23-2007, 08:04 AM
