Results 1 to 10 of 10
Thread: Pressure tank issues
    DIY Junior Member COFFEEHOUND's Avatar
    Jul 2011
    Ontario CANADA
    Default Pressure tank issues
    i have a trickle system set up with no issues from the submersible to the tank.lots of water.
    I have water form the holding tank to the xtrol tank.
    The problem is this
    the jet pump comes on and hits it's cut off no problem.
    after it hits cut off and the pump shuts down.the tank drops pressure and the pump fires again over and over.after it fills if I turn the pump off the pressure drops until the gauge hits about 20.
    We only bought this house less than a year ago and the pumps and tanks all look fairly new.
    I have no issues with plumbing but this is the first place i have been with a well system
    Any help would be apreciated.
    Feb 2011
    NW Ontario, Canada
    How many gallons is the bladder tank and how many gallons of drawdown can you get from it? How long does it take for the pump to go from kick-in to kick-out? It sounds like maybe the bladder is busted and you have too little drawdown.
    Jul 2011
    Ontario CANADA
    not sure on the gallons of the tank but it is a well-x-troll 201 tank.pump runs for aprox.30 seconds i am guessing.no change as to the amount of run time from what it normally would
    Jul 2011
    Ontario CANADA
    you can hear what sounds like air after the pump shuts down.almost like a backflow.
    Moderator valveman's Avatar
    Mar 2006
    You have a bad check valve or a hole in the pipe.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by COFFEEHOUND View Post
    Odd though why it stops leaking once it hits 20 PSI. Maybe the pressure gauge won't go lower than 20.
    Jul 2011
    Ontario CANADA
    Well thats the thing.I see no check valve in the line.if i had a hole anywhere i would probably see water somewhere there.
    I think what i may do is soap up all areas of the tank and pump in the morning.
    thanks for all the help so far guys.much apreciated
    Jul 2011
    Ontario CANADA
    Thank you to everyone for your help..Turns out the foot valve came off of the line and is why the pressure tank would not hold water pressure.
    Working fine now
    Feb 2011
    NW Ontario, Canada
    But how could it hold at 20 PSI with no footvalve?
    Jul 2011
    Ontario CANADA
    LOL.. I taped the gauge and it dropped the pressure reading.. must be a lil sticky.
  1. Grundfos Constant Pressure System Issues--Fluctuating Pressure
    By Alan Adamson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-15-2011, 08:56 AM
  2. New Water Tank Pressure Issues - looking for best and brightest.
    By jcdephi in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2010, 06:16 PM
  3. expansion tank issues
    By James W in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2009, 03:05 AM
  4. well tank issues
    By the newcomer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-10-2009, 06:43 AM
  5. Well & Pressure Tank Issues?
    By BrianP in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-08-2006, 05:32 AM
