Results 1 to 9 of 9
Thread: Water issues....please help!
    DIY Junior Member red dog's Avatar
    Jul 2011
    Bloomfield, ny
    Default Water issues....please help!
    Hi All! Wondering if anyone has suggestions for taking care of my water issues? I had a test done that showed I have 20grains hardness and 1part Iron. When the man checked my sample he said I had hydrogen sulfide just from smelling the sample. I also have a low flow rate of 1.64.
    I raised 4 children in this home monitoring their showers at 5 minutes each(before turning off hot water!). We had a water softener that seemed to help with the iron staining but that is no longer functioning. I just bought a new washing machine(front loader) and would like to take care of our water issues before installation. Any suggestions? Thank you in advance!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    When you say you have a low flow of 1.64 is that gallons per minute? If so, you would need a system to increase the flow rate before any equipment to correct the water issues.
    Dec 2009
    Alaska
    Sounds like a water storage tank of 500 gallons.
    Treat the water going into the tank and then pull water from the tank to clean the system.
    This is some thing that is done around here any number of times.
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by Akpsdvan View Post
    Very interesting. Clean the water before the holding tank but use the clean water to regen the unit. Wouldn't that require solenoid valve to control the water? I've sold storage tanks before but would have never thought of treating the water prior to the holding tank.
    Last edited by mialynette2003; 07-09-2011 at 10:05 AM. Reason: Additional thoughts
    Dec 2009
    Alaska
    Oh yes solenoids are part of the set up, and a kill switch for the well pump so that it does not run while the system is cleaning with the clean water.
    Then in the holding or storage tank put in a flow control of 1gpm.
    Now if the well and pressure tank have enough storage then use the no hard water bypass piston in the 2510 and save the use of solenoids....
    Jul 2011
    Bloomfield, ny
    Yes, the flow rate is 1.64gpm.
    Jul 2011
    Bloomfield, ny
    I'm thinking of going with a chlorinator, holding tank (i found a 200 gal. that would fit thru the door), a jet pump to take water from holding tank to our pressure tank, then to a terminox filter to remove iron etc. to a softener then possibly a reverse osmosis system under sink to get rid of chlorine etc. Does this sound like over kill or reasonable? Any suggestions on where to purchase the equipment? Thank you all for your input and suggestions! Please add onto anything I missed. If I need certain valves please suggest them along with placement.
    Dec 2009
    Alaska
    I have a feeling that if you go with the 200 that it is going to be under sized...the filter when it cleans is going to take up most of the useable part of the 200 gallon tank.
    GRUNDFOS STAINLESS STEEL MQ 3/4 HP BOOSTER PUMP would be a good pump to pull from a storage tank to feed the house, no pressure tank needed.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by red dog View Post
    You could chain 2 or 3 tanks together for more capacity but use up a lot of space. A large buried tank might be the way to go. I've heard bad things about those MQ pumps. I would go with a 1000 gallon underground tank and put a submersible in it.
  1. Many water issues
    By red dog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-08-2011, 02:00 PM
  2. water line issues between shower and hot water tank drain P-trap
    By ns in forum Plumbing Forum Discussion & Blog
    Last Post: 03-02-2011, 10:55 AM
  3. Hot water issues
    By ChrisandMel in forum Plumbing Forum Discussion & Blog
    Last Post: 08-04-2010, 02:15 PM
  4. Hot water issues
    By spta97 in forum Boiler Forum
    Last Post: 04-14-2010, 05:20 PM
  5. Hot water issues
    By Cygarbuff in forum Plumbing Forum Discussion & Blog
    Last Post: 12-20-2004, 09:24 AM
