Results 1 to 5 of 5
Thread: Aqualine Shower Knob Replacement
    DIY Junior Member paul_d's Avatar
    Jul 2011
    Warren, ohio
    Default Aqualine Shower Knob Replacement
    Single handle Aqualine Shower Handle. The one we have (which is broken) is plastic with a metal collar w/set screw. Looks like the shaft it fits on is 3/16 w/flat spot for set screw. Plastic under collar is broken.
    Where do I find, manufacturer or replacement handle.
    Many Thanks
    Paul_d
    Plumber jimbo's Avatar
    Aqualine, and Sears, were brand names for the Valley product line. All are now defunt, and parts are getting a little harder to find, but go to any good plumbing store ( probably NOT the local box store ) and look for Valley handles.
    A Delta single handle shower lever will work as a last resort, but the set screw will either be on the opposite side from the flat or the handle will be upside down.
    Jul 2011
    Warren, ohio
    Thanks for the replies, I will check out the Valley Products, and the Delta single handle
    Many Thanks
    Paul_D
    If your old handle was a round knob, a lever handle will seem to work backwards unless you understand that the "top" of the handle will point to the "temperature" range, not the lever itself. i.e., with a Delta handle you swing it to the counterclockwise for cold water, but a round handle rotates clockwise for cold.
  1. Funky Aqualine toilet
    By Terry in forum Toilet Forum discussions
    Last Post: 07-15-2011, 03:02 PM
  2. shower knob
    By volleywood in forum Shower & bathtub Forum & Blog
    Last Post: 01-23-2008, 07:26 PM
  3. Two knob to three knob shower?
    By enviroko in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2007, 06:32 AM
  4. Aqualine in my home
    By goldenroadrunner in forum Shower & bathtub Forum & Blog
    Last Post: 03-05-2007, 06:27 AM
  5. single-handle Aqualine shower handle
    By marchat in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2006, 02:18 PM
