I woke up this morning to less pressure than we normally have. I went downstairs to check the pump and the pressure gauge was at about 30psi, but my irrigation system is running, not sure if that has anything to do with it. I shut the breaker for the well pump and when I turned it back on, the pressure gauge would tick-tock between 40psi and about 60-70psi and go back to 40, then to 60-70 without the well pump turning on at all.
Is this normal or something I need to be concerned about and need to fix before a major problem occurs (like I had on Memorial Day....http://www.terrylove.com/forums/show...!!!&highlight= Everything has been fine since.
Please let me know if this is of concern or normal function.
Thanks!!!
