Results 1 to 7 of 7
Thread: box fill for metal 42 cu in box
    DIY Junior Member Antonio4791's Avatar
    Jul 2010
    South Pasadena CA
    Default box fill for metal 42 cu in box
    Hi all,
    I'm adding 4 new circuits to my main panel for a kitchen remodel. To get the new wires from the panel into my house, I added a new conduit from the panel which enters into my crawl space. The new conduit goes to a junction box. I will have 4 hots, 4 neutrals and 4 grounds coming into this box, via the conduit (1 inch EMT). Going out of the junction box I will have 4 romex cables (going to the 4 new circuits).
    I have a 42 cubic inch metal box. There is nothing in the box other than spliced wire and wire nuts. I think this should be OK. Here is my calculation:
    I have 8 hots, 8 neutrals and 8 grounds in the box. The grounds as a whole count as one conductor. The 8 hots and 8 neutrals add to 16 conductors. That's a total of 17 conductors. To my knowledge each 12 awg wire counts as 2.25 cu inch. So I have 17 x 2.25 = 38.25. So I think I should be fine. Can someone confirm this.
    Mar 2011
    Long Island, NY
    Lightbulb
    This one interests me as well
    Jun 2007
    North Carolina
    Quote Originally Posted by Antonio4791 View Post
    Your math is correct.
    My chart calls a # 12 = 2.62 cu.in. which would make you a bit undersized, but in the real world it probably does not make a big difference.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    You could have used one ground wire from the panel, but the math is correct, just like Mike said.
    Yes I am A Pirate-Jimmy Buffett
    Jul 2010
    South Pasadena CA
    Default thanks
    Thanks guys. I'll continue with my plan.
    Now I will have everything on dedicated circuits.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    The NEC allowance for #14 is 2 CI, for #12 2.25 CI.
  1. Water use - hissing G-Max Korky 528 fill valve - Quiet Fill
    By urdrwho in forum Toilet Forum discussions
    Last Post: 09-23-2012, 04:15 PM
  2. fv75 fill pro delta toilet fill valve operation
    By SuperSewist in forum Toilet Forum discussions
    Last Post: 11-07-2010, 08:01 AM
  3. An All-metal Dishwasher Air Gap
    By ehseger in forum Plumbing Forum Discussion & Blog
    Last Post: 10-03-2009, 03:19 PM
  4. Metal to Metal connections
    By valvemistress in forum Plumbing Forum Discussion & Blog
    Last Post: 06-14-2008, 08:07 AM
  5. Toilet flange that is PVC & Metal (metal is Rusted)
    By Donnaml in forum Toilet Forum discussions
    Last Post: 01-22-2006, 07:45 AM
