Thread: 3/4" pvc pipe seems to have swollen/expanded
    DIY Junior Member sshepherd's Avatar
    Jul 2011
    Pendleton Oregon
    Default 3/4" pvc pipe seems to have swollen/expanded
    I put in a new irrigation system last spring. I hadn't hooked up the drip system last year and am attempting to do so now except the pipe that I put in last year is just slightly bigger that the fitting that I just bought. The extra pipe in the garage (same pvc pipe) still fits the new couplers. I have tried sanding but it did not help. Any suggestions? Why did the pipe swell?
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    Although I have never run into a swolen pipe I have had deformed ends that will not fit a new fitting. Do you have room to cut the pipe back 1 or 2 inches, that should get you a clean fit.
    Feb 2011
    NW Ontario, Canada
    Is this flex or rigid PVC? Flex PVC has a much lower pressure rating and so exposure to high pressure at warm temperatures could account for the swelling.
  1. "real-world" vintage cast iron pipe cutting?
    By zimmee66 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-04-2013, 01:07 PM
  2. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2011, 04:51 PM
  3. Shower Steam Generator Pipe in Contact with "Pink" Insulation
    By JuanSigned in forum Plumbing Forum Discussion & Blog
    Last Post: 01-30-2011, 04:52 PM
  4. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
    By diecastdawg in forum Plumbing Forum Discussion & Blog
    Last Post: 01-19-2010, 10:53 AM
  5. Do I really need the "Water Stop Device"? (Washing machine inlet pipe)
    By Mr Skills in forum Plumbing Forum Discussion & Blog
    Last Post: 11-18-2008, 05:47 PM
