Welcome to Terry's Forums glchaparral,
You may want to check to make sure that the pressure that you have set on your controller is not higher that the pump can deliver.
You could have a defective pressure sensor, Or bad Pump.
What is your controller pressure setting at, and what is the pressure that you are getting on the output of the tank ?
DonL
