Results 1 to 13 of 13
Thread: Toro Jar Top Solenoid Valve Installation
    DIY Junior Member k11's Avatar
    Jul 2011
    British Columbia, Canada
    Default Toro Jar Top Solenoid Valve Installation
    Hello: Great site with lots of good info!
    We moved into a house with a Toro irrigation system. The valves installed are Toro jar top inline valves (53708) (see attached picture). Is there a trick to installing the solenoid. It screws in fine if I take out the solenoid plunger, but with the plunger in, the threads just don't make contact.
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    It takes a little downward pressure to engage the threads because of the spring. Just be persistent and careful not to cross-thread the solenoid and you will get it in time. I know it's frustrating at times but almost all solenoids have the same trouble.
    Mar 2011
    Long Island, NY
    K11,
    I use the same valves in part of my system, and I have found that the plunger must be the exact type as belongs in that valve or else the threads won't engage. something with the length of the plunger I guess. I am not an irrigation tech, but over the years I have installed and replaced lots of Genie, and Toro valves and have gained lots of frustration and experience with them. I can't argue with a pro, but I am just posting from my experience. Any brand new toro Jartop valve I ever opened and re-assembled without losing or mixing up parts always went back together for me with no problem at all.
    Jul 2011
    I tried it again this morning and I still can't seem to get the threads to meet. The plunger is the original one that came out of the solenoid and I checked a good valve to make sure I was installing the parts correctly. (Had no problem re-installing the good one.)
    Is it possible that the solenoid is U/S? The system was working fine last year, but when I tried turning it on in the spring some were leaking, and I noticed they looked like they were slightly pushed out and seem to be cross threaded.
    Mar 2011
    Long Island, NY
    Then I guess they were not properly drained/winterized and ice damaged them. Normally, though, the valve body would crack, but it depends on where there was remaining water.
    Jul 2011
    We did blow out the system, but I think that the compressor we had may have been under powered for the job. I will try getting new solenoids and see how that goes. Thanks for the help!
    Jun 2011
    Portland, OR
    I just had to replace a solenoid in an older model toro jar-top valve today and found that the right one is the toro 89-0114. Although the toro catalog says a universal solenoid will work the book is wrong. I think this could be why your having problems getting the new solenoid to seat.
    Jul 2011
    The weird thing is that it is not a new solenoid. It's the same one that was in the valve last year when the system was working. I checked out the toro 89-0114, it looks a bit different than the one I have. Here are some pics.
Size:  15.5 KBName:  solenoid2.jpg
Size:  15.0 KBName:  jar-top-in-line-valve-(53708).jpg
    Jun 2011
    Portland, OR
    Did you try instaling it with or without the white plunger cap. My experiance with the universal solenoids is to instal them without this cap.
    Jul 2011
    I will try installing it without the cap tomorrow. Right now it's dark and I will get eaten by mosquitoes. What is the cap suppose to do? They seem to break apart very easily.
    Jun 2011
    Portland, OR
    I belive it's just to hold the plunger in place during storage and transport before instalation. That's why I like rain birds encapsilated solenoid, no loose parts.
    Jul 2011
    Just thought I would give a little update on my problem.
    I finally got new solenoids and they installed easily. The old ones must have been damaged from freezing over the winter. (Will have to get a better compressor and do it right next time.) I had some valves that were stuck in the open position. From what I read, the Toro jar top valves are very sensitive to debris, so I took a bucket of water out with me, took them apart, and washed them. I had to wash one a couple times, but I did end up getting them to work properly.
    briankeating
    Guest
    You will have to consider getting new solenoid valves or you can also try the Pneumatic Solenoid Valves. Either of them should solve the issue.
  1. New Solenoid Always On
    By Pat Mc in forum Irrigation / Sprinkler Forum
    Last Post: 06-12-2011, 11:57 PM
  2. Pressure difference between Bleed Valve vs Solenoid
    By mattofatto in forum Irrigation / Sprinkler Forum
    Last Post: 07-25-2009, 09:08 PM
  3. Solenoid function on a irrigation valve?
    By pmaru77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 07:27 PM
  4. Gas Valve Solenoid
    By Thatguy in forum HVAC Heating & Cooling
    Last Post: 12-23-2008, 06:37 AM
  5. Toro valve help
    By Tom Keiser in forum Irrigation / Sprinkler Forum
    Last Post: 07-07-2006, 09:23 AM
