Thread: Advice On Correct Wax Ring ?
    DIY Junior Member soca's Avatar
    Jun 2011
    Southern California
    Default Advice On Correct Wax Ring ?
    This is a follow-up post to my previous post entitled " Unusual Alternating Toilet Flushing Pattern ".
    I pulled the toilet. HJ was correct. The wax ring ( with no boot ) was matted with Palm tree roots. A big root surfaced on each side of the flange where the floor bolts are mounted. One of these roots entered the sewer pipe. I pulled a 3 foot long bundle of Palm tree roots out of the sewer pipe. The flange is in good shape and sits flat on the cement slab. The opening is 3 1/2 inch diameter. I don't see any bolts attaching the flange to the cement. Does this indicate that the plumber probably just glued the flange to the sewer pipe ? The linoleum sits slightly above the level of the cement. It's also aged and curled on the edges and the plumber packed the area with alot of caulk. There are 3 washers stuck to the cement where the front of the toilet sits on the cement. I assume that these are shimms ? Please help me select the correct replacement wax ring. In my area I am pretty much limited to buying it at ACE or Home Depot. Thanks much for any help on the wax ring or any other reinstall advise that you have.
    Plumber jimbo's Avatar
    You will find 4 or 5 slightly different wax rings in the store. Ask 20 plumbers and you will get 25 recommendations about which is "the only one to use".
    Don't lose sleep over it.
    Jun 2011
    Southern California
    I mentioned that the diameter of the flange opening is 3 1/2 inches. I noticed that the metal flange has a plastic or rubber insert in it. Without that insert the opening looks like 4 inches. It looks like that insert can be pulled out. What is this insert for ? Was it part of the wax ring ? It didn't appear to be attached to the wax ring. Can someone please explain what this insert is ?
    Aug 2009
    South*East
    That was part of the old wax ring. They come with and with out the insert. Stay away from the one with the insert. It can cause a obstruction that can result in a stoppage.
    John
  1. Rod replacement vs correct the h2o
    By corky p in forum Water Heater Forum, Tanks
    Last Post: 10-17-2009, 07:17 AM
  2. Flange/wax ring advice
    By T_Finan in forum Toilet Forum discussions
    Last Post: 12-03-2008, 02:29 PM
  3. Correct Fittings
    By RavensFan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-02-2007, 02:28 PM
  4. What is correct air pressure
    By bernprov3 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-25-2006, 02:25 PM
  5. Is my venting correct?
    By dave the bell man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2005, 11:03 AM
