Results 1 to 5 of 5
Thread: New water heater, dripping water in tank?
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default New water heater, dripping water in tank?
    Hey all,
    My dad and I installed a new 30 gal hot water tank, gas. Everything went well except for one thing.
    When taking a shower or using the hot water, you can hear the water heater fire up. Then if you listen to it closely, it sounds like water is dripping inside the tank onto the flame. Sorta if you took a pot and put it on the flame with no water, then put a drop of water in the pot. Thats the noise.
    I'm not sure when it stops but it does stop when nobody is using the hot water.
    What's going on? Internal leak?
    DIY Junior Member DanTee's Avatar
    Jun 2011
    ohio
    i remember hearing that when i first started installing gas water heaters. we figured out it was condensation from the cold water in the tank and the hot flame under it caused it stopped shortly after we fired the tank up.
    Jun 2006
    New York
    Quote Originally Posted by DanTee View Post
    interesting but it goes for a while. hmmmmm
    What dantee describes is very common and normal. It happens for sure on first start up, when the bottom of the tank is very cold with the fill of new water. It does not happen so much once the tank is heated, but can recur for example on a long shower when you are taking a lot of hot water out and replacing it with cold. 30 gallon is a pretty small tank, good for maybe one shower. A long shower ( 10 minutes) will use up all the hot, so now the tank is cold again, and condensation happens again.
    A 30 gallon water heater is going to go "cold" very rapidly, and once that happens, the combustion gases are going to condense water and drip onto the burner causing a sizzling sound.
  1. Tankless water heater or tank? How about for this particular use?
    By dereks in forum Plumbing Forum Discussion & Blog
    Last Post: 07-25-2011, 12:59 PM
  2. hot water hearter (tank) has drain to outside and is dripping.
    By gcsm33 in forum Water Heater Forum, Tanks
    Last Post: 01-18-2010, 06:17 PM
  3. Replies: 4
    Last Post: 07-10-2009, 01:43 PM
  4. New water heater, existing water softener, expansion tank needed?
    By dhancock in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2009, 08:09 PM
  5. No Expansion Tank for Water Heater
    By vasanvasan in forum Plumbing Forum Discussion & Blog
    Last Post: 01-14-2006, 06:34 AM
