A vent can't go down from its initial connection...otherwise, it would get clogged with crud, water, waste, and not provide the venting function - it needs to be a sloped path to open air to work. You might be a candidate for use of an island vent scheme (search here for how to do that). An AAV might have problems if you have a garbage disposal...AAV's let air in, not out, and a GD can act like a pump and pressurize the line...this needs to go somewhere, and an AAV won't (or at least shouldn't) let anything out.
