Did the gfi trip, or did the light never work after you put on the GFI?? Certainly you need to verify that the hot goes to line, and the downstream circuit is connected to "load". You also have to be careful that the load connected to the "load" terminal of the GFI does not have a multiple connection to neutrals downstream, such that not all of the current flows back to the neutral "load" terminal on the GFI. Or the corollary to that...that neutral current from a load connected to a different hot source also flows back to the GFI.
, but I am a pro crastinator
