Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Installing a 3 gallon heater ca?----
    DIY Member bsa_bob's Avatar
    Jan 2011
    britton mich
    Default Installing a 3 gallon heater ca?----
    Can i just install a heater this size just below my k sink in the basement? And pipe it in series, with my hot side of the faucet above. I"m looking to save running off so much water[wasteing well water]and get hot water quicker for her to wipe off the kitchen table
    This will refill the 3 gallon tank and make it ready for the next use........although----------will i be running the electric too much ?-and to often. Any help greatly appreciated ----btw --- where do i pickup this heater and which is the best for the money??-------- thank you again bob s -
    Ps i forgot to say my house is long and the main heater is on the opposite end of the faucet.I'll be tapping into the main hot water supplyline. like i say "in series"
    Feb 2011
    NW Ontario, Canada
    Why not just install Watts/Grundfos Comfort recirc and keep the space under the sink? The recirc can also give you instant warm water at other taps in the house. A 3 gallon heater wil give you 3 gallons of hot water followed by cold water.
    Jan 2011
    britton mich
    MAN!! I 'm forgetting this stuff fast. Thank you for the reply.So you are saying to just recirculate the hot --at the main heater its self.?????????I had it in my head the hot water would be coming thru the, 3 gallon heater ,hot.But it won't, it will have to release all the stored cold water; before i get hot water, unless i never use much water. at the hot faucet.Her and i are senior citizens.I have to find one of these grunfos set-ups??
    Jan 2008
    There are several different hot water recirculation systems, each with their own advantages and disadvantages.
    The best systems use a recirculation pump at the water heater and have a dedicated recirculation pipe running from the pump to the furthest fixture from the heater.
    Jan 2011
    britton mich
    Dedicated line?? This is a line that runs from the recic pump, to the faucet and back..one line out of the pump,and one line back to pump, with the faucet in the middle.is this right???????
    A recirculating line runs from the furthest hot water fixture back to the water heater. The pump is in the recirculating line close to the heater and only involves the recirculating line. There are several brands of systems available, all work pretty much the same. I use a Laing and it has performed well for several years. They come with or without timers.
    Yes, but in many cases it is difficult, if not impossible, to retrofit a dedicated return line. A retro circulation system, such as the Grundfos, will give fast, NOT immediate, hot water to EVERY faucet between the heater and the "crossover" valve. Your 2 gallon heater under the sink WILL give immediate hot water, up to 2 gallons, but do NOTHING for the intermediate faucets. And, that little heater WILL have a T&P valve which will require that its discharge pipe be run out through the exterior of the house.
    Feb 2011
    NW Ontario, Canada
    A retrofit recirc that uses the existing cold line for the return is not for everyone. If you drink cold water straight from the tap, then forget it, as the cold side becomes warm.
    HJ is right that a retrofit recirc that uses the existing cold line for the return won't give you instant hot. I was careful not to make that claim and rather used the term instant warm. In many cases people don't really need instant hot and just want instant warm. Also many people these days get their drinking water from the door of the fridge or via a RO spigot.
    Mar 2011
    Houston, TX
    Quote Originally Posted by bsa_bob View Post
    Sounds like a lot of expense and trouble, Just to clean the kitchen table.
    Why not use a tea kettle to heat the water ?
    Old School...
    Feb 2011
    NW Ontario, Canada
    There exist also, on-demand retrofit recirc systems without dedicated return. You push a button a minute or so before you draw the water. That way you don't always have tepid water in the cold line.
    Most any recirc system can be setup to only run on demand. The simplest one to install IF you have power underneath the sink is the RedyTemp unit. Takes all of around 10-minutes and you'd probably only need a pair of pliers if the hoses are tight to the faucet. I have one of these in my bathroom. It has its advantages and disadvantages. There's often a receptacle under the sink for things like the garbage disposal, and you may have an unswitched space free, so this would be simple. Rarely is there an outlet under a vanity. I pulled a new lead off the bathroom's one and cut a new one in there for mine, but if you can't do this yourself, it's often less to have it done at the WH, where there is likely already power, and, it allows for multiple crossovers, if desired, to ensure the whole house gets the instant water. In my situation, the vanity it is in the furthest thing from the WH, so the whole house gets the advantage of the circulation. Mine's about 8-years old and still working fine. I have it on a timer so it only runs when needed during the time I'm generally up.
    Jan 2011
    britton mich
    Old School...
    That was just an example i would think it was so when i typed it.theres many other times she needs this type of thing so i fix it up for her.
    Jan 2011
    britton mich
    This redi-temp also sounds like it may be what is needed in my long run. thank you jad nashua
    Jan 2011
    britton mich
    I just want good warm water in the kitchen within a couple of minutes, the warmth of the water isn't bothering me as much as. --the large amount of water going down the drain. i have to stop this.
    Jan 2008
    You may be thinking about this in the wrong way. Running well water down the drain for a couple of minutes is not really wasting it at all. It's no different than watering your garden or lawn, in that eventually most of the water ends up back in the ground and back to the water table.
    If your plumbing is accessable in the basement or crawlspace, installing a dedicated recirc pipe should not be a problem. Install a pump that uses a timer and thermostatic controls to prevent it from running when it is not needed, and you will be golden.
  1. Instant on Water heater? or 80 gallon or both?
    By mikki499 in forum Remodel Forum & Blog
    Last Post: 01-26-2011, 05:17 AM
  2. 50 or 55 gallon water heater cost ??
    By ballvalve in forum Water Heater Forum, Tanks
    Last Post: 01-15-2011, 11:41 AM
  3. Pan for a water heater - regular 50 gallon tank
    By richard8 in forum Water Heater Forum, Tanks
    Last Post: 04-05-2010, 01:14 PM
  4. Nine Year Old 50 Gallon Water Heater
    By hudson in forum Water Heater Forum, Tanks
    Last Post: 04-12-2009, 05:44 PM
  5. Ariston 2.5GL gallon electric tank water heater
    By Cali in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-27-2008, 07:27 AM
