Fudog
- Messages
- 28
- Reaction score
- 0
- Points
- 0
Good Morning, and Happy 4th, I have a leaky main shut off water valve in the house that I would like to replace with a 1/4 turn ball valve and would like to install it in a way that if it would have to be replaced I could unsrew it and remove without any soldering so should I use a union on one end or both ends or compression fittings or Sharkbites?Also when soldering a brass fitting onto copper pipe is there a method to doing it such as alot more heat maybe? What kind of gas do you pros use? Acetylene, Mapp Gas ,or Propane and where could I get the long hose with the regulator and smaller tip for tight spaces? Thanks ! Enjoy the Holiday.
