Capacitor for 1hp submersible pump
jk76
Indianapolis IN
I converted my house about a year ago to city water and would now like to run the irrigation off the well. The current pump is a 1/2hp 5gpm pump thats been in the well for over 30 years, the new pump is 1hp 25gpm. The old pump and new pump both need a control box to run, can I use the old control box and just switch the capacitor. Do I even need to switch the capacitor?
Also I found a wx-252 a while back on craigslist that I thought I would use as my holding tank. Do I even need a holding tank if the well will be used only for irrigation?
DonL
Houston, TX
I would make sure that the cap matches the pump motor winding.
And using the tank would be better than no reserve.
I do believe that Having the tank would make the system perform better, and last longer.
Have a great day.
DonL
