Results 1 to 4 of 4
Thread: Capacitor for 1hp submersible pump
    DIY Junior Member jk76's Avatar
    Aug 2010
    Indianapolis IN
    Default Capacitor for 1hp submersible pump
    I converted my house about a year ago to city water and would now like to run the irrigation off the well. The current pump is a 1/2hp 5gpm pump thats been in the well for over 30 years, the new pump is 1hp 25gpm. The old pump and new pump both need a control box to run, can I use the old control box and just switch the capacitor. Do I even need to switch the capacitor?
    Also I found a wx-252 a while back on craigslist that I thought I would use as my holding tank. Do I even need a holding tank if the well will be used only for irrigation?
    Mar 2011
    Houston, TX
    I would make sure that the cap matches the pump motor winding.
    And using the tank would be better than no reserve.
    I do believe that Having the tank would make the system perform better, and last longer.
    Have a great day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Use the tank rather than a pump start switch or better yet to extend the life of the pump and keep it from cycling install a Pside-Kick http://www.cyclestopvalves.com/pdf/p...k-brochure.pdf .
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Dec 2009
    northfork, california
    You will need a new control box.
  1. Need Help Finding 0.75 mfd capacitor
    By SNYD in forum Electrical Forum discussion & Blog
    Last Post: 11-03-2009, 08:31 PM
  2. capacitor burn out
    By dragnuts in forum Electrical Forum discussion & Blog
    Last Post: 10-21-2009, 09:20 AM
  3. AC blower starting capacitor
    By Bobver in forum HVAC Heating & Cooling
    Last Post: 06-30-2009, 11:19 AM
  4. Capacitor problems
    By chefkelbel in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-27-2008, 04:41 AM
  5. Capacitor burnt up in control box
    By sfloyd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-09-2008, 06:56 AM
