Results 1 to 8 of 8
Thread: Submersible pump humming
    DIY Junior Member kplank's Avatar
    Jul 2010
    Kansas
    Default Submersible pump humming
    I have a 1 hp Myers Rustler pump set at 40' in a 45' well. Static water is at 19'. 1 inch 60 lb plastic Cycle Stop Valve in the drop pipe. 1 inch poly pipe to the house. Ridged copper throughout the house.
    Every time the pump runs, there is a fairly pronounced humming sound that gets transmitted through the pipes in the house. I have changed the metal straps holding the copper to plastic hangers. This helped a little, but not much.
    Is there anything I can plumb either before or after the bladder tank that would help cut back this noise?
    Mar 2011
    Houston, TX
    That is a two wire pump I do believe, and that pump has a run Capacitor built into it.
    You may want to check that it is good. there is a reason that it is humming.
    How old is it ? And did it always do this ?
    Have a good day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Moderator valveman's Avatar
    Mar 2006
    Sometimes the length of drop pipe is perfectly tuned to the resonance frequency of the pump. Shortening or lengthing the drop pipe a foot or two will usually make it go away. An easier fix would be to use a short piece of 1" high pressure hose to splice between the well pipe and the copper.
    Jul 2010
    Kansas
    Default It has always hummed...
    At least as long as we have lived here (three years). The pump is 3 wire - control box with the capacitor in the house.
    I guess I'm not familiar with the type of "high pressure hose" I would plumb in between the pump and the copper. Right now black poly from the well, transitions to PVC at and around the tank, which transitions to copper to the house. Where do you get "high pressure hose", and where would I put it?
    Feb 2011
    NW Ontario, Canada
    I deliberately strapped a loop of the poly from the well to the underside of my floor joists so that I can hear when the pump is running. The plan was to replace the metal pipe strapping with rubber bungee cords one at a time to tune down the sound to a barely audible level but I never did.
    DIY Member gritres's Avatar
    Jun 2011
    nw florida
    one likes to hear their hard work working
    i'm curious too though what type of high pressure hose you'd recommend to dampen the sound that is good for potable applications
    DIY Junior Member Behrens88's Avatar
    Dec 2011
    Michigan
    Default Humming is good.
    I have had two pumps in my well since I have lived in my house for 10 years and both have always hummed. The newest is a 1 horse 20 GPM Areomotor that hummed out of the box. I just learned to get over it and it lets me know my pump works I guess.
    Dec 2009
    northfork, california
    Most hardware stores have 150 psi braided clear vinyl hose. I have some running at 100 psi for 10 years with no decay.
    http://www.plumbingsupply.com/cleartubing.html
    Best thing around the pump house. Quick install, quick fix and a visual of the water.
    And HUMMING is not good. Usually a sign of an issue. A run capacitor might help.
  1. SUBMERSIBLE PUMP 110 or 220
    By loudhornsrule in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2010, 10:18 PM
  2. Gould jet pump humming tripping breaker
    By Casey56 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2010, 10:43 AM
  3. new submersible pump for well
    By tula-dan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2010, 04:07 PM
  4. Ejector pump constantly humming, not ejecting
    By tgrooves in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-28-2007, 08:23 AM
  5. Submersible Pump
    By dgray in forum Plumbing Forum Discussion & Blog
    Last Post: 08-10-2007, 11:42 AM
