Results 1 to 5 of 5
Thread: Low flow situation with GSW John Wood
    Feb 2011
    NW Ontario, Canada
    Default Low flow situation with GSW John Wood
    I've got a rental tank - gas - power vent - 6G40NVH-FV-02 - B4743 http://www.gswpartsonline.com/model/27345
    It seems to have some sort of device in it that limits flow. I think it is some energy saving anti-perc valve but looking at the parts list linked above, cannot see any such thing listed. Under normal conditions, whenever hot water is drawn I can hear something clunking in the tank.
    Anyway... yesterday I shut off the water to the house to clean/replace some filters. I didn't drain the HWT nor the lines after the softener. I did drain/flush the precip tank on the iron filter. Invariably some air does get into the house plumbing which may stir up some iron sediment.
    Afterwards, I flushed out the cold water lines and drained off a tiny amount of sediment from the bottom of the HWT to make sure the water ran clear. The last thing I want is for the wife to have anything short of crystal clear water in her soaker tub. I systematically go from nearest faucet to furthest faucet purging first the cold lines and then repeat with the hot. The only one I didn't do is the tub filler because I'd have to wash out the tub if any water were to splash onto the surface. Throughout this purging, I did not notice the limited flow on the hot side since all the other fixtures are themselves flow restricted.
    My confidence that her bathing experience would be without incident, was shattered when she turned on the tub filler. Keep in mind this is a large soaker tub and as such the tub filler has full bore valves... no pressure balance spool, no flow restrictor of any kind. The cold side ran full bore as usual but the hot side was but a fraction of the bore.
    I was finally able to restore the flow by repeatedly opening and closing the whole house draincock in the crawlspace until i finally heard that familair clunking again from the HWT. Anyone know what and where the source of the clunking is and if in fact it could be the source of the flow restriction? If so, can it be removed?
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    There are two plastic check valves in the inlet and outlet to the tank. Yes they can be removed, just remove the hot and cold connections and pull them out with needle nose pliers.
    Feb 2011
    NW Ontario, Canada
    I found this picture of the nipple but it sure doesn't look like the innards come out.
    http://www.gswpartsonline.com/part/3912
    http://www.gswpartsonline.com/part/3912/view
    Aug 2009
    BC
    They do come out, Its a common problem. I have removed lots of them.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    just replace the 2 nipples with brass nipples
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Great John Toilet Company
    By Terry in forum Toilet Forum discussions
    Last Post: 06-25-2010, 07:02 AM
  2. Wood Propane Wood Pellets
    By FrankMueller in forum HVAC Heating & Cooling
    Last Post: 07-21-2008, 06:09 PM
  3. Smelly John
    By Thnatos in forum Toilet Forum discussions
    Last Post: 10-07-2005, 03:27 PM
  4. John Bridge Tile forum
    Last Post: 08-21-2005, 08:58 AM
  5. What happened to John Bridge?
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2005, 06:58 AM
