Results 1 to 8 of 8
Thread: Clothes Washer - new drain - suds overflow
    DIY Junior Member wmellott's Avatar
    Jun 2011
    CT
    Default Clothes Washer - new drain - suds overflow
    We recently had the washer moved and a new 2" drain installed, but now we seem to be getting Suds overflow.
    Break down:
    Tapped into the main 3" a exit of house to sept tank i.e. right at the cast iron joint to PCV. run to sept tank about 10ft.
    Distance from main to washer is 7ft, pitch was set at 1/4 in per foot, yes there is a 2" check valve, flapper type.
    P trap at washer with 8 inch stack pipe.
    Further FYI: top of stack pipe is about 12"~14" above main leaving house. We are not using any more/less soap then we have been, stillsame MFG.
    Old system on other side of room is 1 1/2 copper with about a 20~24" stack pipe - never had this problem drains into other house sept sys. 3" copper, run to tank is about 30~40ft
    I am wondering is stack pipe is not "long enough"? but extending would be a propential issue
    Ideas?
    bill
    Aug 2009
    South*East
    Did you vent the new drain and what is the reason for the check valve?
    John
    Jun 2011
    CT
    Quote Originally Posted by johnjh2o1 View Post
    John
    John, the 2" ties it at the very end of the entire house out to the sept tank.
    The house is a "raised ranch" i.e the washer is in the lower level.
    So IF by chance the main out to the tank clogged and backed up, we need the check valve to stop flow into the washer which is now the "lowest point"
    Vented - well no seperate vent perse, its open like most other washer drains I have seen, the venting would come from the 3" main etc.
    Doesn't seem much different then the original copper (other side of room) except:
    1.) The copper goes to a lower point then the washer & 1 1/2 vs 2 pvc
    2.) The stack on the old copper is say 20~24 inch high
    Overall a more ideal situation and it indicates why when they built the house they put it there and not where it is now (which is where they had intended since I found the markings on inside of the wall)
    3.) It is not feasible to cut the cement slab and run over to the copper side
    Bill
    The 2" washer p-trap needs a vent within five feet.
    I like to see the 2" standpipe be 18" or more.
    Mar 2011
    Houston, TX
    Yes, What Terry said, That would probable cure your problem.
    Enjoy Terry's forums and make a donation... (sorry Terry but you deserve it...I did not mean to advertize)
    Enjoy your day.
    DonL
    Jun 2011
    CT
    Thanks Terry,
    Ok attached are the two pic's
    #1 is 3" main with 2" coming off
    #2 is the 2" coming through wall directly behind washer. Note the "Tape joint"
    Last night I got a 2" coupler and another 10" of pipe to try and extend the stack to about 18" I didn't glue it just used duct tape as a temp
Size:  55.8 KBName:  washdrain2.jpg
    Bill
    Add a vent downstream of the p-trap and get rid of the check valve.
    You can use an AAV if you can't go through the ceiling.
    Jun 2011
    CT
    Thanks, I thought about a AAV, but figured it wouldn't need it since normally the pipe end is open.
    Can't risk getting rid of the check valve, that 3" main comes from the upstairs, 2 toilets, 1 shower, 1 tub/shower, kitchen...
    That could be just an incredible mess in the worst case senario.... I can take the water.. the other stuff that sometimes comes with it..not so much.
    Bill
  1. using tankless water heater with dishwasher and clothes washer
    By rafael in forum Tankless Water Heater Forum
    Last Post: 06-03-2010, 06:07 AM
  2. Clothes washer rough-in
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2010, 05:16 AM
  3. Clothes Washer drain size
    Last Post: 05-16-2010, 11:47 AM
  4. Washing machine makes toilet overflow with suds - ?
    By pogo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2009, 04:22 AM
  5. Installing Clothes Washer/Dryer in Basement
    By Still_Waters_43 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2006, 04:54 PM
