Thread: What's the requirement when a buried PEX supply crosses over a buried drain line?
    DIY Junior Member Seattle's Avatar
    May 2011
    Seattle, WA
    Default What's the requirement when a buried PEX supply crosses over a buried drain line?
    I'm converting a garage into living space and am connecting the water supply, drains & electrical from the main house to this garage building. The city requires the garage to share everything with the house.
    I'm still in the design phase but need to start plumbing and electrical in the next week.
    My supply is PEX which will be buried in its own trench at 12" deep. A second trench for the drain/sewer will also be 12" deep. A third trench is the buried electrical conduit at 18" deep.
    Is there anything special I need to do when any of these lines cross each other which they will have to at one point in the yard?
    I think I could do one trench for both sewer & supply but I'd have to make it 24" deep and have a shelf at 12" which seems more difficult than just digging separate trenches.
    Thanks for any ideas.
    Nov 2010
    Maine
    the PEX needs to be a minimum of 12" above the waste line
    Plastic water lines typically have to be at least 18" deep to prevent damage. You will need a very experienced plumber to install the plumbing if the sewer trench is only 12" deep. Most need a 20"+ trench for the way they know how to do drainage piping.
  1. Material for replacement buried main water line from the curb?
    By greendog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 11:41 AM
  2. Searching for buried water line
    By Mary in Texas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2010, 06:35 AM
  3. Pin Holes in Buried Copper
    By theestimator1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2008, 10:28 PM
  4. insulating buried supply line
    By jnrwood in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-19-2008, 09:30 AM
  5. Capping a buried gas stub
    By metlc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2005, 06:08 AM
