Thread: Sporadic Power to GFI
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Sporadic Power to GFI
    I have a GFI that has only sporadic power going to it. The breaker seems fine, but all the outlets downstream from this one GFI have no power.
    I removed the GFI and all the wires going to it to test the live wire pair for power. It showed power for a few seconds and then lost power again. The breakers were all reset and seem fine and no breaker has ever been tripped.
    What could account for this sporadic power?
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    Sounds like a loose wire,
    Works a few moments until the heat causes the wire in the junction to expand and break contact.
    I am assuming that if wait a few moments to half an hour that the power comes back on...
    First isloate the wire run, turn off all breakers except for that one and then test all outlets and lights to see if there are devices installed before the GFIC
    Hopefully there will be a loose wire in a outlet box.
    On occasion the boxes can be in the attic or under the home. Code says that the junction boxes are to be accessable but that does not always happen.
    Michael
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    Mar 2011
    Long Island, NY
    And hopefully you do find the cause quickly, because if it is as saccity said, a loose connection, it can overheat and be quite dangerous. Especially so if your house was built in the 70's and wired with aluminum cables that have not been replaced with copper or properly "pigtailed" . Don't mean to scare you, but you should find and fix the problem.
    Bob
  1. Is there enough power here
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 07-19-2009, 06:36 PM
  2. lap top no power
    By cwhyu2 in forum Computers and Stuff
    Last Post: 06-16-2009, 07:09 PM
  3. Sporadic water pressure increases
    By beachbum64 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2009, 03:35 PM
  4. Sporadic Shower Leak
    By mbrennan in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2008, 08:31 PM
  5. Sporadic No Water Well Problems
    By kesmith in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-14-2007, 11:43 AM
