Results 1 to 5 of 5
Thread: Electric Water Heater Expansion Tank - Bondiing?
Hybrid View
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Electric Water Heater Expansion Tank - Bondiing?
    Installing a new electric water heater in cottage. Have noted in plumbing how-to books, that an expansion tank was situated on the cold water line before entering the water heater cold water inlet.
    Is this a new requirement, and what is the benefit. Water heater will be on a well, not city water supply. It will have its own expansion tank.
    Also on gas fired water heaters, should you bond the hot and cold water pipes to the natureal gas pipe as well.
    Thanks.
    Since your well has a bladder tank you shouldn't need an expansion tank, as long as the water heater is on the same line as the well.
    In answer to your second part, you should not bond the hot and cold water pipes to the natural gas pipe.
    Feb 2011
    NW Ontario, Canada
    If you have metal piping, it should be bonded to the electrical service ground. Unless there is a dielectric union insulating the hot side, it should already be bonded through the water heater. The gas piping should already be bonded at the service entrance. No need for additional bonding at the tank.
    I have a theory, that the hot and cold SHOULD be bonded together at the water heater, especially when di-electric unions are used.
    As noted, the well's bladder tank should be able to handle any expansion as long as you don't have any extra check valves, you should not need it. But, some locales may require one. You need someplace for water to go when you have a closed system, and a check valve creates that. As long as the bladder tank is on the same side of the check valve as the WH, in theory, no extra one needed.
  1. Water Heater Expansion Tank
    By Roccoo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2009, 04:55 AM
  2. Location of expansion tank w.r.t. water heater
    By jdf405 in forum Tankless Water Heater Forum
    Last Post: 07-10-2009, 01:34 PM
  3. Expansion Tank for a Hot Water Heater
    By driem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2008, 06:01 AM
  4. thermal expansion tank for water heater?
    By scrappy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2007, 12:48 PM
  5. No Expansion Tank for Water Heater
    By vasanvasan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2006, 06:34 AM
