Results 1 to 3 of 3
Thread: natural gas valve
    DIY Junior Member hoody0107's Avatar
    Aug 2011
    Duluth, Ga
    Default natural gas valve
    My sister is having a problem with her gas water heater. The pilot light was not staying lit so she had someone replace the thermocouple. This did not fix th problem so she had someone else come in and replace the valve. The replacement valve did not work at all. The old valve was rated at 5 psi and the new one was rated for 3 psi. Would the psi rating matter on a natural gas water heater. If not what else could the problem be.
    Is it not staying lit when you try to light the pilot, or does it go out after you turn it on once?
    Yakima WA
    How much trial and error are you going to before you call a professional? Keep screwing around with something you know nothing about can kill you especially if it's gas!
  1. Natural Gas Questions
    By figs in forum Plumbing Forum Discussion & Blog
    Last Post: 05-18-2008, 07:31 AM
  2. LP to natural gas
    By jerseybob in forum Plumbing Forum Discussion & Blog
    Last Post: 10-19-2007, 10:56 AM
  3. Natural Gas Odor, Bad Valve on Empire?
    By molo in forum HVAC Heating & Cooling
    Last Post: 09-15-2007, 05:58 PM
  4. natural convection
    By danothemano in forum Plumbing Forum Discussion & Blog
    Last Post: 08-24-2006, 04:47 PM
  5. Natural gas barbeque
    By jadnashua in forum Plumbing Forum Discussion & Blog
    Last Post: 02-15-2006, 09:56 AM
