My partner and I are about to place a 1 HP pump down our 8" well casing. It's about 200' to water and 350' to bottom. Due to droughts in the past we want to put the pump deep (say 20' off the bottom) in case the water table drops in the future. The pipe is 1" dia black poly (?).
Our concern is the weight and how to control it as we lower it down. We intend to use rope and we have these nice poly rings that hold pipe, wire and rope and centered on the well casing. We were told to place one every 20' or so. We're thinking of locating the bucket to our tractor about 4 ft in the air directly above the casing (turning the bucket down and placing a blanket on it to make the edge smooth and soft), and then draping the pump, pipe, wire and rope over this to control things as we lower down. That way the pump, wire, and rope will be vertical as it lowers down. My job will be to put the spacers on every twenty feet or so. If we stretch out the pipe, wire and rope for 240' on the ground before we start, won't there be a lot of resistance at first? I'm envisioning having to pull the pipe and wire toward the well to make it lower down until the weight going down exceeds the friction/resistance of the pipe and wire on the ground. Does any of this make sense? Can anyone suggest a better way and/or offer advice?
Other questions:
1. The torque arrestor is such a flimsy rubber thing. I expected something different. How much clearance should we allow between it and the casing?
2. I read that one should NOT use a torch to expand the black pipe to fit it on to the pipe nipple because it will make the pipe brittle. The article said to use hot water (65 C) instead. Is this important? I've always used a torch before, but I've only worked with shallow, cattle watering systems.
3. Any other advice anyone can offer would be appreciated.
Other questions:
