Results 1 to 2 of 2
Thread: Jet Pump For Non-Pressurized Solar System?
Threaded View
    DIY Junior Member atw58's Avatar
    Jun 2011
    Toronto, ON
    Default Jet Pump For Non-Pressurized Solar System?
    Hi all,
    I am installing a non-pressurized solar water heater on the roof. It has a 40 gal storage tank connected to evacuated tubes which heats the water using thermosyphon. A solenoid controls filling the roof tank with cold water when the water level is side the tank drops below a certain point.
    Since this system is non-pressurized, it needs a pump to bring the hot water up to 40/50 psi before feeding the hot water side of the home's plumbing. The pump will be in the basement and the distance between the tank of the roof and pump is 25-30 ft. We currently have a 40 gal natural gas hot water tank.
    Ok, here are my questions:
    - What type and size of pump should be used shallow well jet, jacuzzi, etc.
    - Can the pump feed hot water supply directly or is a water pressure tank needed. If so what should the size be.
    - The water temperature can be as high as 150 F. Does this affect pump selection or water pressure tank.
    I appreciate any advice you have.
    Thanks,
    atw58
  1. pump to solar/wood stove drainback water heating system inconsistant
    By trillium50 in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-06-2011, 08:32 PM
  2. Problems with old solar hot water system
    By cocolema in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-24-2010, 08:25 AM
  3. solar salt vs system saver pellets
    By bob tenthousand in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-22-2009, 10:10 PM
  4. Dumping into Pressurized Water System?
    By molo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-14-2008, 06:54 AM
  5. Solar Flat Plate draindown system
    By Rancher in forum HVAC Heating & Cooling
    Last Post: 02-27-2008, 12:39 PM
