Thread: Does a well have to be vented?
    DIY Junior Member Shooter45's Avatar
    Mar 2011
    MS
    Default Does a well have to be vented?
    Our new well is not vented other than the hole where the wires go through which is open for anything to crawl through and down the well. Any suggestions? If it does not have to be vented I'll just silicone it up.
    Moderator valveman's Avatar
    Mar 2006
    Without a vent the well can be under a vaccuum which can draw critters in from other places. Silion the wires but put in a vent with a screen pointed down using two elbows.
    Feb 2011
    NW Ontario, Canada
    Whether or not the well would benefit from being vented depends on the well. A well casing can act as a storage reservoir and the pump may draw it down faster than the well can produce. The well can then recover between pump cycles. Sealing the top of the well could cause water to be forced at greater GPM from the bottom and could in some cases bring up sand.
    Mar 2011
    MS
    Thanks. Bought the pipe and vented it today. Also siliconed the wires outlet.
  1. one vented fixture in whole house?
    By joni41 in forum Remodel Forum & Blog
    Last Post: 08-02-2009, 10:07 AM
  2. Where should toilet be vented
    By Vinniejt76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-30-2008, 11:20 AM
  3. Self-vented electric dryer
    By ip1275 in forum Remodel Forum & Blog
    Last Post: 03-03-2008, 02:51 PM
  4. direct vented vs vent free
    By pswachtel in forum HVAC Heating & Cooling
    Last Post: 10-02-2007, 04:35 PM
  5. is this drain adequately vented?
    By adrianmariano in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2007, 05:41 AM
