Results 1 to 14 of 14
Thread: Replacing 5 HP submersible pump
    DIY Junior Member dryman's Avatar
    Jun 2011
    ECenTEXAS
    Default Replacing 5 HP submersible pump
    I have an old 4" well with a 5 hp submersible pump set at 200' (I think). It is on 2" galvanized pipe. The moter has been out for years and I want to replace it. I already purchased a new pump and motor but realized I may have bitten off more than I can handle. I was going to build a tri-pod out of 1 1/2" heavy wall square tubing to pull the pump with but am concerned about the weight I would be pulling. I have a set of 2" elevators for the pipe also. Does anyone have any advice for such a project other than hiring a "professional"? We are in a MAJOR drought here in Texas, all the service companies are busy, and I need the water for my cattle. Any helpful advice would be appreciated. Thanks
    Mar 2011
    Houston, TX
    Welcome to Terry's Forums dryman.
    If it is a 5 HP then that sounds like a job for a pro. Are sure it is 5 HP ?
    Have a great day.
    DonL.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    There are lots and lots of things a person can DIY. Some save you money, some give you self-satisfaction.
    In my opinion, this is not one of those. I use a rig like the one pictured above. The job can be dangerous. One mistake and you can lose a hand or a finger, or destroy the well. If the pump were to drop it would head to the bottom like a missle and probably destroy the screen.
    What part of Tx are you in?
    Jun 2011
    ECenTEXAS
    Thanks for the advice, I am located north of Giddings. I am sure it is a 5 hp motor, I used it for irrigation water in the past.
    Mar 2011
    Houston, TX
    dryman,
    If It is on 2" galvanized pipe, then Texas Wellman may be correct.
    It would a lot safer to have someone like him to help you.
    You live in Gods country, I have been told.
    Have a great day.
    DonL
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    It can be done by a qualified DIY but like Texas Wellman said, it's best left to the professionals. The possible damaged limbs, pump and destroyed well cost could far exceed the savings. Understood it's costly to have a professional do the job but believe me in this case I recommend it!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Jun 2011
    ECenTEXAS
    Thanks for your comments. I will let a professional handle this for me and I feel much better about my decision. I will post on here what the outcome is. Again, thanks for your help.
    Feb 2010
    SE Texas-Coastal
    Probably a good idea. I don't really know anybody in that area to recommend. It is getting very dry here also. We had a good bit of rain last week but now we're back to being dry.
    Jun 2011
    ECenTEXAS
    Yes, we got some much needed rain last week too. It greened things up but will not last long. I think my biggest problem is that most companies I talked to said I was out of their service area.
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    You have made the right decision. Extracting this type of equipment, especially without experience and just the right tools, can be dangerous.
    Quote Originally Posted by dryman View Post
    Chris Kofer
    h2oguy.com
    Jun 2011
    ECenTEXAS
    I found a company out of Hearne, Tx that said they would replace the pump for me. Very friendly individuals, I will get a cost estimate this Tuesday, the guy that is in charge of repairs was out yesterday. They did say I will need new wire so this could get expensive. dryman
    Mar 2011
    Houston, TX
    After all the work involved dryman, It is best to do it right the first time. That is cheaper in the long run.
    Have a good holiday weekend, be safe.
    DonL
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    If it's Brien then you should be in good hands.
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    Jun 2011
    ECenTEXAS
    Yes, those are the ones.
  1. SUBMERSIBLE PUMP 110 or 220
    By loudhornsrule in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2010, 10:18 PM
  2. Replacing 32 yearold submersible pump
    By bogdan530 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-11-2010, 05:54 PM
  3. Submersible pump going bad?
    By psyclemania in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-07-2009, 11:56 AM
  4. Replacing storage tanks with bigger submersible well pumps
    By luc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-29-2009, 05:56 AM
  5. Replacing submersible pump
    By dirtmover in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-05-2007, 09:17 AM
