Results 1 to 10 of 10
Thread: Non Electric Gas Boiler
    DIY Junior Member CharlieK's Avatar
    Jun 2011
    Philadelphia, PA
    Default Non Electric Gas Boiler
    Years ago I had a house with a natural gas steam boiler controlled by a milliivolt thermostat. When the power went out my boiler kept running having no need for electricity. As a builder we have a few clients looking to have their heat not be electric grid dependent. Anything made today that's more modern and effocient than my old unit that might do the same using NG or propane?
    Mar 2011
    Long Island, NY
    check with your local propane dealer and/or the public utilty that supplies natural gas. That's what I would do.
    In the trades Dana's Avatar
    Jan 2009
    Old-school high-mass steam or gravity-feed convecting hydronic systems rarely exceed ~60% efficiency, but there's no inherent reason a properly sized lower mass steam boiler with millivolt controls couldn't hit 70-75%. I'm not sure that would meet minimum efficiency & valving safety standards for legal sale in the US though.
    Convecting millivolt wall furnaces exist (probably operating in the ~75% efficiency range), eg:
    http://www.empirecomfort.com/EMPIREC...llFurnaces.pdf
    There are probably low-voltage DC versions that could run code-legal valves, but it still wouldn't meet code on minimum efficiency.
    To get higher AFUE efficiency than 78% usually requires some sort of blower or pump to generate sufficient turbulence for more effective heat exchange.
    http://www.empirecomfort.com/EMPIREC...fficientDV.pdf
    Nov 2010
    Maine
    But Dana, he wants to know if he can get a new one and as far as I know the present energy standards won't allow anying with a standing pilot for heating.
    Jan 2009
    For hydronic boilers 80% AFUE is achievable and legal with standing pilot ignition, but that requires pumps and some power to run the gas valves.
    Min-legal spec on steam is 75% AFUE, (also achievable with standing pilot, without forced-draft burners), but codes don't allow the type of gas valving used on millivolt systems, so it's still grid-dependent on the internal controls, even if it uses next to zero electricity.
    So bottom line, no, with the possible exception of off-grid cabins other situations where millivolt wall furnaces might be permitted, your options for zero grid-power heating systems are nil. Some DC-systems with designed for big RVs and the like might cut it if your heat loads are miniscule, but I don't have a handle on that market.
    The "nonelectric" boilers had to be either steam or gravity hot water, neither of which is very popular these days. A thermopile could operate a gas valve to turn the burner on and off, but that was all.
    Nov 2010
    Maine
    Besides the advent of more complicated and safer control systems the main reason why you can't do what you want is because millivolt thrermostatically controlled gas valves had a nasty habit of failing in the full on position.
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    There is little purpose in being "off the grid" if you have to depend on the propane truck.
    Answer; wood-fired out door boiler with DC motor.
    DIY Member tk03's Avatar
    Jan 2011
    Harrisburg, pa
    As everyone stated above the Milli-volt is no longer available in boilers. You can still buy 24 volt standing pilot boilers. Manufacturers can build them until Sept 1, 2012.
    Badger good point about the LP truck.
    quote; There is little purpose in being "off the grid" if you have to depend on the propane truck.
    That is why the propane tank has a gauge on it with the red zone being once it reaches 20%. You should NOT wait until it is empty to call for a refill. If your propane truck cannot get to you with a couple of week's notice, you are buying from the wrong company.
  1. Combining an electric Tank with electric Tankless
    By Dkrasko in forum Tankless Water Heater Forum
    Last Post: 03-27-2014, 08:24 AM
  2. Replies: 9
    Last Post: 10-29-2011, 05:36 AM
  3. Electric water hear connected to Gas fired Boiler
    By Winemakr in forum Boiler Forum
    Last Post: 01-09-2011, 10:50 AM
  4. Converting from On Demand Coil (Oil Boiler) to Electric Hot Water Tank.
    By mikeangelini in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-21-2008, 01:08 PM
  5. Replace dinosaur electric with electric, power or direct vent?
    By mr_littlejeans in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2008, 03:36 AM
