Results 1 to 8 of 8
Thread: wiring 220V Stenner pump to pressure switch
    DIY Member Flipperman2a2w's Avatar
    Feb 2011
    North Carolina
    Default wiring 220V Stenner pump to pressure switch
    I suppose this is a hybrid well/electrical question. . . Has anyone ever wired a 220V Stenner pump directly to the pressure switch, so that it kicks on when the well pump starts? Stenner says not to chop the end of the plug off, but I always take that with a grain of salt. I thought about installing an outlet and wiring the outlet to the pressure switch, but that seems kind of redundant.
    I have a three wire 230V (3/4 hp) submersible pump. Can I just loosen the screws where the power comes into the pressure switch and slip the wires for the Stenner underneath the screws?
    CT pump guy Teets's Avatar
    Aug 2007
    Watertown, Connecticut
    Yes, you can cut the plug and with the power off attach the 2 power wires from the plug under the terminal screws for the well pump and attach the ground wire from the stenner pump plug to the ground screw on the pressure switch. Be aware if you do this, Stenner will most likely under any condition not warranty the pump.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Flipperman2a2w View Post
    If you want to make it run when the pump is on then you would have to connect it to the LOAD side of the pressure switch and not the input where the power comes in.
    If you cut the plug off to wire it then it may not meet electrical code, but would work, as long as you do not exceed the current rating of the pressure switch.
    Your outlet idea may be better, If you have to meet your electrical code.
    DonL
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    In my opinion, an outlet on the load side of the switch that also serves as a junction box for the well pump wires is the only way this should be done.
    Chris Kofer
    h2oguy.com
    Feb 2011
    NW Ontario, Canada
    That's some hack job wiring on the pressure switch and I would not add any more wires to it.
    Since you say you have a 3 wire pump, there must be a control box between the switch and the pump. Wire the outlet to the switched line side of the control box.
    Normally, the wires would be inserted UNDER the metal plates on the screws, not directly under the screw heads. If the pump is still under warranty, the manufacturer will void it if the cord is cut for ANY reason.
    Feb 2011
    Northwood NH
    Which pressure switch are you using?
    Chris Kofer
    h2oguy.com
    Feb 2011
    NW Ontario, Canada
    Looks like a Square-D which doesn't use loose plates under the screws. Normally the wire is bent into a U for better contact under the screw head.
  1. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  2. I think pressure switch is not receiving pressure from pump.
    By jeremytl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-04-2011, 06:26 AM
  3. Replies: 17
    Last Post: 01-24-2011, 08:44 AM
  4. Myers 220v 1.5HP Pump No Flow
    By rgapinski in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-01-2008, 07:56 PM
  5. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
