Results 1 to 5 of 5
Thread: Need help with drainage in back yard
    DIY Junior Member Michael Rudd's Avatar
    Jun 2011
    Virginia
    Default Need help with drainage in back yard
    I wrapped concrete around the back of my house for decorative and drainage purposes, but on one side I cant figure out how to complete the drain. The pre-existing drain is higher than I can make the new drain to allow proper drainage when I tie into the existing drain. It would cost way too much time and money to completely redo the entire thing, so is there any ideas on how I can get the slope needed in the new line to allow it to drain into the old line? I could pour an extreme amount of concrete to get the height, but that would cause a lot of new problems. Thanks for your time.
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    First, do you know where the old line drains to and can you run the new line to a lower point on the old line. The other option is a dry well if you have a spot to put it.
    DIY Junior Member MikeRudd's Avatar
    Jun 2011
    Virginia
    The lower point in the existing line is not accessible due to a concrete floor. What exactly is a dry well?
    Jun 2011
    Portland, OR
    A dry well is basicly a hole a couple of feet around and up to six feet deep and filled with drain rock to help disperse the water. The depth depends on how much water and how fast a dispersal you are looking for. The drain rock can also be coverd by filter paper topped by bark or 6" to 8" of soil and sod.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Have you thought about pump drainage?
  1. Sewer gas from stack, stinking out back yard
    By burleymike in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2011, 04:43 PM
  2. Confused By Drainage Problem in Front Yard
    By plumbingnewbie in forum Drain Cleaning
    Last Post: 03-29-2011, 07:23 AM
  3. AWFUL SMELL IN THE BACK YARD and it is a tree
    By Dunbar Plumbing in forum Computers and Stuff
    Last Post: 06-15-2009, 09:12 PM
  4. Adding bathroom back to back with existing - share 3 inch branch?
    By mturse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2008, 07:25 AM
  5. Critters are ripping up my back yard
    By skippertom in forum Lawn Care/Landscaping
    Last Post: 08-02-2006, 06:16 AM
