Don't know on the electrical, but it's easier (but more materials, and therefore could be more expensive especially if the tile are pricey) to tile under the island, then install. This gives you the advantage of not having to try to cut all those extra tiles, caulking and grouting under the toekick, and, if you decide to take it out, it will probably make installation of a new island cabinet easier as the size then isn't critical. It does make it harder to anchor the island, but in concrete, probably not by much. You'll probably need a diamond core bit to drill a hole in the tile, although some softer tile can be drilled with carbide.
, but I am a pro crastinator
