Results 16 to 30 of 40
Thread: Does a torn wire jacket violate California electric code?
  1. #16
    Jun 2007
    North Carolina
    Since underwater splices are made with rubber splicing tape and then covered with scotch 33 it sure seems that would be safe on this wire.
    no no no no no
  2. #17
    Mar 2011
    Houston, TX
    I agree it would be safe.
    It is safe now as is, because the cable sheathing is cut back when you terminate the connection, normally.
    And if the inner conductors are not nicked then the outer sheathing plays little role in safety.
    It just keeps the conductors together in one bundle.
    But Up to Code ? Depends on the inspector.
    DonL
  3. #18
    Dec 2009
    northfork, california
    Much ado about nothing.
    Considering how my rats strip many feet of ROMEX® BARE, I wonder why its allowed at all. It needs a aluminum shield.
    REAL ROMEX® once had lead shielding.
  4. #19
    Plumber jimbo's Avatar
    I suggest you double check what we are talking about. The wire you showdoes not look line " house wiring ". It looks like low voltage wire, and all of the mini split A/C that I am familiar with do NOT send line voltage to the inside. Line voltage ( 120 or 240) feeds the outside unit, and low voltage control wires, including 34 VDC to run the inside fan, go in on 18 ga. thermostat wire.
  5. #20
    Mar 2011
    Houston, TX
    They use to put Arsenic in the wire insulation so that rodents would not eat it. We used it on runs across the desert.
    DonL
  6. #21
    Mar 2011
    Houston, TX
    I think the same thing jimbo.
    It is good quality wire with the pull string reinforcement build into the wire.
    But its gauge makes it about the size you would use for long runs, when used as a control wire.
    I do not think it is a big issue, But I don't live in California, and the rules differ.
    Enjoy your afternoon.
    DonL
  7. #22
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    That's funny, I realize you are a plumber and probably install these systems all the time, but every one I have ever wired (and that is a lot of 'em) has sent line voltage between the units.
  8. #23
    Jun 2007
    NY State, USA
    Also, if you look closely, it says "600V" on that cable in the picture. That is definitely line voltage cable.
    Actually it looks more like cord, which means it is unlikely that that is an actual image of the cable used.
  9. #24
    I am familiar with LG and Friedrich. In poking around on line, I did find that Mitsubushi and Sanyo do feed line voltage from out to in...
    I am still curious about that cable he showed in the pic. Does it look like 14 or 12 ga? or smaller?
  10. #25
    Feb 2011
    NW Ontario, Canada
    The writing on it says 14/4.
    Around here we need to use #12 AWG wire for 20 amps.
  11. #26
    Nov 2009
    VA
    Guys,
    The pic is not of his wire. He just grabbed a pic off the web. Here is what he said:
    I've attached a web image that will give you an idea what this cable looks like, but mine looks like it has another black jacket underneath the one that's torn.
    It would be best to get a pic of the real install. It may need a new wire ran or the problem area may be able to be placed in a junction box and ran from there (assuming it would be accessible).
  12. #27
    Jun 2007
    NY State, USA
    This is not the circuit conductor cable. It is feeding the outside unit from the inside unit.
  13. #28
    Jun 2007
    NY State, USA
    Quote Originally Posted by nukeman View Post
    Or, since there is just a small 1.5" tear in just the cable jacket, it CAN be repaired with electrical tape.
  14. #29
    DIY Junior Member LCroft's Avatar
    Jun 2011
    California
    Sorry guys didnt mean to start a war!
    Actually after taking a closeup of the cable it's apparent that the installers used the wrong cable. The cable they used says SJEW E54864 (UL) 300V 90*C CSA LL39753 SJTW(TPE). The install manual calls for 600V insulation on the cable. BTW its a Mitsubishi.Name:  Power-Cable-Closeup.jpg
  15. #30
    Jun 2007
    NY State, USA
    What war??? All I see is a discussion.
    Why would they call for 600V cable? the only difference between 300V and 600V cable is the jacket thickness. 600V cable like that is for hard usage.
  1. Replies: 4
    Last Post: 08-22-2010, 05:25 PM
  2. California: New closet flange code?
    By Greg98 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-24-2010, 05:54 PM
  3. Bath Electric Code
    By jerome8283 in forum Electrical Forum discussion & Blog
    Last Post: 04-21-2008, 01:31 PM
  4. California code questions - water heaters
    By mikeyvon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2008, 03:12 PM
  5. California plumbing code question
    By Kelley G in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2007, 08:18 AM
