Results 1 to 8 of 8
Thread: sprinklers won't turn on
    DIY Junior Member Emily Verstraete's Avatar
    Jun 2011
    Kelowna, BC
    Default sprinklers won't turn on
    I tried to turn on my sprinklers yesterday after they have been dormant for the winter. Only one of the three stations will turn on. What could the problem be?
    One possibility is the common wire (usually white) is broken. That wire is linked from one valve to the next, usually connected with waterproof wire nut. If the connection is lost after the first valve in the chain, #1 would work but the follow valves would not. You didn't mention which valve in the chain comes on, so this is just a stab in the dark. Waterproof wire nuts can be purchased, but regular nuts with silicone packed will work just fine too.
    Plumber jimbo's Avatar
    Go to each valve and try to turn on manually, by slightly unscrewing the solenoid one turn or so. You may have to disassemble some valves, blow out the bleed ports, maybe replace some solenoids. And of course dont rule out wiring problems as mentioned by gary
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    As gary said the most likely cause is a bad wire connection if station 1 comes on but 2 and 3 do not. If 2 or 3 comes on and the others do not check the flow control knobs in the center of the valves. Sometimes if the knob was turned partway down a slight change in pressure will keep them from opening.
    DIY Junior Member casey.robert.irving's Avatar
    Jun 2011
    Atlanta, GA
    Default Agreed
    Quote Originally Posted by mike1059 View Post
    I agree 100% with both of them.
    Jun 2011
    Kelowna, BC
    What if my station 2 turns on but not 1 or 3?
    Mar 2011
    Long Island, NY
    I think Jimbo gave you very good advice by trying to operate the manually. did all 3 valve work when tried manually?
    Jun 2011
    Portland, OR
    If all valves open manualy and all the valves are in the same valve box it is most likely the wire connections. If they are in differant boxes it could be a broken wire.
  1. can a multi-turn shutoff turn itself on?
    By dekelly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2009, 07:26 AM
  2. Sprinklers come on then immediately turn off
    By lonestar54 in forum Irrigation / Sprinkler Forum
    Last Post: 06-20-2008, 03:55 AM
  3. Sprinklers Won't Turn On
    By stevecrissi in forum Irrigation / Sprinkler Forum
    Last Post: 04-10-2008, 06:34 AM
  4. how far to turn sink, tub, or toilet shutoff valves to turn on water
    By ydelamater in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 06:28 PM
  5. Manually opening the valves won't turn on sprinklers
    By CluelessinTexas in forum Irrigation / Sprinkler Forum
    Last Post: 08-02-2007, 06:29 AM
