Thread: Injector Pump Running Continuously (not switching off)
    DIY Junior Member thanksFORtheHELP's Avatar
    Jun 2011
    Chicago Area
    Default Injector Pump Running Continuously (not switching off)
    Hello,
    The injector pump in my crawlspace is running continuously and is not switching itself off.
    This has happened in the past and usually it somehow corrects itself after a few days but I have a few questions about this particular problem....
    1.)Do I need to worry about the motor on the pump overheating because it's running continuously? If so, how often should I switch it off so it can cool down and for how long?
    2.)What would end up happening if the pump burned out?
    3.) Would could possibly be causing this to happen? I am guessing something is causing whatever triggers the machine to turn off to stick and it thinks there is still stuff to pump out?
    I should also add the I have tried several different things such as unplugging the pump and switching the circuit off for awhile in hopes of it resetting but that does not work. The well the pump is in is sealed by thick plastic (permaseal) and I do not have access to it to open it up.
    Any other information you may need me to provide, just let me know. Thanks in advance for the help....
    Last edited by thanksFORtheHELP; 06-16-2011 at 01:26 PM. Reason: added 3rd question
    Jan 2008
    A sewage ejector pump and/or a sump pump both use a float switch to turn the pump on and off. It is common for the switches to fail. Sometimes stuff in the basin can also stop the float from moving freely, which will prevent the switch from operating properly.
    If the pump is running and not pumping any liquids, it will cause it to fail prematurely. I would fix the switch immediately, as it would be a lot cheaper that replacing a burned-out pump.
    Jun 2011
    Chicago Area
    Thanks for the info....
    Luckily, yesterday, shortly after I posted this thread, the pump managed to turn off and started to work properly.
    Jan 2008
    That's kind of like saying that your car leaked out 5 quarts of oil yesterday, but it's not leaking anymore so it must be ok.
  1. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  2. Air Injector question again vs Mazzi Injector
    By K Paterson in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-10-2010, 08:04 AM
  3. Sewage Injector Pump needs replacing?
    By ncyewest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2009, 10:05 AM
  4. Well Pump Running Continuously (Would This Cause Ground Saturation)
    By invisible-man in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-24-2008, 08:44 PM
  5. sewer gas odor from injector pump
    By rickagresta in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-23-2005, 04:34 PM
