Tonelious
The fan relay on my water to air heat pump has a loose connector. if you jiggle the wire it cuts on and off. my problem is choosing the correct one to replace it. I have a cold-flow heat pump the old relay is an S&E I cant find any information on this company the tag reads as follows. SE90340 contact rating 12afl 60alr 125v 6afl 35alr 250v. It has 4 connectors on top 2 in the center and 4 on the bottom. Looking online for replacement parts some are listed 24v some 120v and some 240. How can I tell which one my old one is. It has a lead from the t24v transformer and a 120v that stays hot.(I`m assuming thats for power when the fan is in the on position not auto. Any help would be greatly appreciated. Terry Love your forum is the best.
