Results 1 to 7 of 7
Thread: Fan relay needs replacing
    DIY Junior Member Tonelious's Avatar
    Jun 2011
    Jacksonville Beach Florida
    Question Fan relay needs replacing
    The fan relay on my water to air heat pump has a loose connector. if you jiggle the wire it cuts on and off. my problem is choosing the correct one to replace it. I have a cold-flow heat pump the old relay is an S&E I cant find any information on this company the tag reads as follows. SE90340 contact rating 12afl 60alr 125v 6afl 35alr 250v. It has 4 connectors on top 2 in the center and 4 on the bottom. Looking online for replacement parts some are listed 24v some 120v and some 240. How can I tell which one my old one is. It has a lead from the t24v transformer and a 120v that stays hot.(I`m assuming thats for power when the fan is in the on position not auto. Any help would be greatly appreciated. Terry Love your forum is the best.
    Mar 2011
    Houston, TX
    Welcome to Terry's Forums Tonelious,
    And you are correct that ; "Terry Love your forum is the best."
    I would look at the connections and see if it is just a connection problem.
    If you replace the relay then the connections going to it are bad, then it still has a problem.
    If it has Crimp connections then I would look at them first.
    Good Luck on your project, and enjoy your day.
    DonL
    Jun 2011
    Thanks for your reply DonL, I checked the connections thats when I found one of the posts was loose on the relay where the 120v lead is connected. I do not think there is any way to tighten or fix it. I did not mention that on my original post but I was trying to keep it as short as possible
    Mar 2011
    Houston, TX
    If you can take it apart then you might be able to solider it.
    A new one would be best, but I would try to repair it and use non acid flux.
    The coil is 24V, here is a place that you can get one;
    http://acpartsdistributors.com/index...oducts_id=1833
    P.S. If it is burnt then maybe your fan run cap is bad or you could have another problem.
    Normally there is a reason that they burn up.
    DonL
    Jun 2011
    Thanks for your help DonL the fan run capacitor was changed last summer. I did the repair on the relay and it seems to be working fine now but I ordered a new one. I am going to install it the first chance I get
    DIY Junior Member misterfixer's Avatar
    Jan 2010
    Charlotte
    Changing the relay or sequencer has become a regular thing for me. Dealing with 15 year old Goodman air handlers, I've found that call backs for no blower operation ceased when I changed the weak capacitor AND the relay at the same time.
    Do an Internet search for your relay's part number and you will find many sources for it.
  1. Relay
    By NJJohn in forum Boiler Forum
    Last Post: 06-13-2009, 02:14 AM
  2. Relay
    By NJJohn in forum HVAC Heating & Cooling
    Last Post: 06-10-2009, 07:07 AM
  3. boiler-relay
    By mi joe in forum HVAC Heating & Cooling
    Last Post: 03-03-2009, 06:36 PM
  4. Switching Relay
    By drspookie in forum HVAC Heating & Cooling
    Last Post: 07-10-2008, 07:52 PM
  5. What Kind of Relay does this need??
    By Brad_1234 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-03-2007, 07:12 PM
