Results 1 to 4 of 4
Thread: Any real advantage to soft water resin rinse?
    DIY Junior Member bgauweiler's Avatar
    May 2011
    La Crosse, WI
    Default Any real advantage to soft water resin rinse?
    Is there any real benefit to regenerating with softened water (from a second tank)? Several manufactures specifically mention this feature of there system as a way to increase resin life and save water and salt.
    Dec 2009
    Alaska
    If you are talking about a twin system, yes there can be some benefits if the water has high iron and hardness to clean the out going tank with the on coming tank.
    One also gets to use the most of a tank before the change thus using less salt over the long term of the system
    What is the water test of your water?
    May 2011
    La Crosse, WI
    I'm on municipal water supply (so I do not think I have a iron problem). Water hardness is 20 Grains. It's just the wife and me in the house now so I'm looking at a 26 or 32K system. I do like the idea of not having to have a full day of reserve capacity possibly wasted (as with a single tank design). Anyone have any experience with vortech tank design?
    Dec 2009
    Alaska
    Have not seen them around here, but in the books from my suppliers... the one that I deal with the most and I are of like mind, we are staying away from it..
    Some may like it but for what I am doing with the turbulator it will not work.
  1. Water tests soft but doesn't feel soft.
    By ninefall in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-06-2010, 07:54 PM
  2. Real time help needed/water main!
    By Seattle38 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-09-2010, 07:02 PM
  3. How does the dshwshr rinse agent get into the rinse?
    By tototalitarian in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2009, 06:15 PM
  4. HELP! Hubby's gone and water pressure is real low
    By Miztiki in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-12-2006, 07:10 PM
  5. Washing Machine Rinse Water Backs Up in Kitchen Sink
    By Francoise in forum Plumbing Forum Discussion & Blog
    Last Post: 01-26-2005, 04:22 AM
