Results 1 to 2 of 2
Thread: pump keeps turning itself off
    DIY Junior Member banksant's Avatar
    Jul 2010
    Ontario
    Default pump keeps turning itself off
    My jet pump which sucks water out of my pond for the sprinkler system turns its self off as soon as I swtich it on. It is not tripping the fuse, the pump itself is just turning off. Is the pump shot? Do i need a new one? It is wired in directly and we have not chagned anyhting to the wiring when it was working ( no extension cords)
    Mar 2011
    Houston, TX
    It may be tripping the motors internal breaker.
    The start switch may not be working or the capacitor may be bad.
    You might want to see if you can rotate the motor shaft, to see if the impeller will turn.
    If it does not turn then you could have a bad bearing, or trash in the pump.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  1. Well Pump Not Turning Off/Holding Tank Not Filling Up
    By tonis01 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-15-2011, 06:10 PM
  2. Air in system and pump turning off
    By Brett_24 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-09-2009, 07:51 PM
  3. pump not running/turning on, contacts normal spark/voltage
    By tnjcreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2008, 06:40 AM
  4. Water Pump Turning On and Off
    By Jeffrey Bovee in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-11-2008, 10:31 AM
  5. Turning off some radiators?
    By sprinkler in forum Plumbing Forum Discussion & Blog
    Last Post: 08-20-2006, 03:18 PM
