Results 1 to 6 of 6
Thread: 10 Inch rough in
    DIY Junior Member bridgji's Avatar
    Jun 2011
    Maine
    Default 10 Inch rough in
    I want to replace an old toilet with an elongated bowl i have in a basement bathroom. The old toilet tanks sits right next to the cement wall. I'd like to put some insulation on the wall so was thinking of going with a 10 Inch rough in toilet to open some space for this. I have a few questions
    1. Will the 10 Inch rough in push further out in front?
    2. If I go with a round toilet would that allow the front to be about in the same space? the space in front is limited also.
    3. The toilet that is currently down there has 4 bolts holding it down; two look like normal bolts going to the flange. The other two appear just to be going to the cement in front of the flange. I assume the two front bolts are just an old style is there anything I should be concerned when replacing it with a current two bolt one?
    Thanks for the help.
    Jim
    It depends on HOW they make it a 10" rough. If they use a conventional 12" bowl with a slimmer tank, then it will be the same. IF it is a dedicated 10" bowl, it will project 2" more, because the opening will be 2" further back from the front of the bowl..
    Jun 2011
    Maine
    Red face 10 Inch rough in
    If I was looking to keep it projecting out about the same I assume could probably go to a round vs elongated and make it up the space. Thanks for the reply
    Toto makes several toilets that use one of their Unifit adapters. These adapters come in 10", 12", and 14" sizes which allow the same toilet to fit any of those rough in sizes. Toto is the only manufacture that makes these adapters and they will only fit selected models. You can find these elsewhere on this site.
    You can also use a American Standard Cadet 3 round bowl with the 10" tank.
    It's a standard 12" bowl with thinner tank.
    Jun 2011
    Maine
    Thanks for the info.
  1. Help: 14 inch rough + 27.5 inch front to back
    By Bost02478 in forum Toilet Forum discussions
    Last Post: 10-06-2009, 08:25 PM
  2. Adapting a 9 inch Rough In to 10 inch Toilet
    By Noddaplumber in forum Toilet Forum discussions
    Last Post: 11-14-2008, 10:18 AM
  3. What's best for a 10 inch rough in
    By vman in forum Toilet Forum discussions
    Last Post: 02-19-2008, 03:45 PM
  4. 11-inch rough-in
    By kajm in forum Toilet Forum discussions
    Last Post: 03-08-2005, 03:01 PM
  5. 10 inch rough in.
    By jrbarnett111 in forum Toilet Forum discussions
    Last Post: 02-04-2005, 07:01 PM
